Question about Vacuums
Palm springs ice maker model js-zbj-10. Can I leave this on all the time? Will the 'new' taste ever go off the ice cubes? Thanks.
2 Suggested Answers
SOURCE: user manual for Palm Springs
I will advice you check manualnguide.com to search for the manual of your device as requested.
Take care.
Posted on Aug 25, 2010
My portable ice maker quit working. The water is not getting to the top ice maker part. The model # MCM30SST. The motor sounds like it is working.
If you have recently moved the fridge, you may have rolled the fridge on top of the water line. This would restrict the water flow to the regulator. If the water line is not pinched, then the regulator is bad. You can replace it for around $25 with a universal part, or pay $50 for the original.
Thank,
Jim
Aug 03, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
Will not produce ice cubes......not freezing correctly
Golly Dang. We've been using our freezer all these years, not knowing the vacuum was supposed to make the ice. And while we're at it, does anybody have a good ice recipe? We lost ours in a fire.
Jun 13, 2011 | Vacuums
Hello - I am trying to find a replacement part for a SNO portable ice maker - it is the rotating plastic plate that collects the ice as it comes off of the freezing nubs then pivots and dumps the ice into...
Hi Scott and welcome to FixYa, I am Kelly.
Your talking about either the T-1A or the T-2M portable ice makers by Whynter. The only think I can recommend is that you contact them directly here:
Phone: 866-WHYNTER Email:info@whynter.com
or use this link to use an on line contact form:
http://www.whynter.com/contact_us
I do not know of any external sources for the part you need.
Their ice maker products are here:
http://www.whynter.com/product/refrigeration/ice_makers
This information is from their product guide:
To obtain service or information, contact
Whynter Innovations Group via Email at service@whynter.com or call 866-WHYNTER
Thanks for choosing FixYa,
Kelly
Jun 12, 2011 | Vacuums
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
Have a windchaser portable ice maker which only makes one cube at a time. I have been told one possibility is a clogged freon tube, but no suggestions on repair. Another is low freon, but I cannot find a...
CAUTION !!! ----freon re-charge should be performed by a trained service person -- this can be very dangerous if trying to perform yourself.
depending on the year of the unit --one thing that I would check is to make sure you have good airflow in and around the unit,, dust and dirt can hinder performance of the unit.
c...
Jan 02, 2011 | Vacuums
Hi I have a new sunbeam Eskimo ice maker I have had it on now for 3 hrs approx the water is cold and i have it on the med size blocks its only bringing down 4 ice blocks in the 3 hr period is that normal...
Sorry to read about your problem, I hope this helps you out.
yes
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Sunbeam Vacuums
I have an Electrolux Model G. I have to take the
Wow an old but a goody.Electrolux rewinds of this age are like land mines. Be very cautious.
The G is similar to its cousin the model 89. In the 89 a service tech would remove the housing cover with the cord spool held secure and stationary stationary and the housing laying flat. Sometimes a clothes pin or small clamp on the outside of the cord housing.....
Once inside there would be a spool with the cord would on and that spool had both a flat metal spring half visible below the side of the spool and and an open center bearing race. Only half the spring would be exposed from above and a special clamp tool was used to reach in and clamp the spring before any parts were disturbed. You might get away with a set of long skinny needle nose pliers but you must not kink the spring by doing so. Then if removing the spool, you would invert the rewind over an ice cream pail to drop the loose bearings , or remove them with a magnetic screwdriver tip.
If your spring is damaged you will get one through Aerus Electrolux , originally Electrrolux US.
If your cord has given way and you are exceptionally careful, without removing the spool you can desolder the terminals on the bakelite spool inside, drill out the rivets holding the contact ring and shorten the cord . this is far easier than attempting to install a new cord .The next step would be to resolder the cord and re rivet the spool contact ring with a pop riveter and washers to secure the tabs cut out in the ring.
If you remove the entire cord you will have to clamp the spring so a snot to lose its unwound tension. This is VERY tricky. Best of luck . please post back to advise what happens.If you impatient, don't even consider this one, just find another G for parts and steal the rewind
Sep 19, 2009 | Vacuums
Vacuums Logo
203 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
