No picture no sound suddenley larg red and small light came on.magnavox 50" tv 50ml8305/17 projection
    Genius:
  • 3,422 Answers
You will need a repairman to fix this up and this is the only solution.
If it is still under warranty just get it replaced.there are several circuits in this tv that could cause this.Or it can be be collapse of the power supply too.A repairman will have to pull it a part and make a few checks to see what it is.
Good luck :)
Please don't forget to rate the solution
Posted on Apr 18, 2008
  • 13,433 Answers
Checking for known causes, one moment.
  • 3 more comments
  • Ekse Apr 18, 2008
    The red lights, what does it read next to them?
  • Ekse Apr 18, 2008
    Its possible that the lamp in your tv has failed, but would like to confirm this if you can post the texts next to the lights.
  • Ekse Apr 18, 2008
    Lamp indicator red : Lamp failed
    Temperature indicator red: Internal temperature too high.
    power indicator red : stand by
    Seems that your tv is in stand by and the lamp has failed.
    In most cases the lamp is user replaceable and cots around 200 to 500 usd.
  • Ekse Apr 18, 2008
    To order a replacement lamp, call the Magnavox Customer Care Center at 1-800-705-2000. A Magnavox associate will be happy to assist you.
    The part number for the Magnavox replacement lamp is SP.L6502G001.
    Warning!
    • Turn off and unplug the unit before you replace the lamp.
    • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
    • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
    • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display.
    http://www.p4c.philips.com/cgi-bin/dcbin...
  • Ekse Apr 18, 2008
    Please remember to rate my solution directly.
Picture but no sound on magnavox tv
My tv which is phillips has sound but no picture,there is two red lights on the front that comes on ,one is for power but what is the other one
Jun 20, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
