Question about Jl Audio 1000/1 Car Audio Amplifier
I have 2 12 inch jlw6's and need a amp but dont know what would be better, if i get 2 jl 500/1 or 1 jl 1000/1, or if other amps out there would be good for a reasonal price, any advice would help...
    Problem Solver:
  • 5 Answers
Yea the jl either setup will be good for those woofers but for the money an to get the power i would try a hifonics 2000 or the 2600 brutis or mtx or2 poweraqustic 4000 planet audio they will work great or give me a call there are a lot of amps to choose for the money an the power
Posted on Jul 25, 2010
My legacy 12 inch subs are making a crackling sound what can do?
Hi rodneybarton
The problem of your unit may be its amplifier. You need to open the box and inside of it, there is a component that attached on the heatsink you need to replace that one. or better send your unit to qualified technician.
Dec 29, 2013 | Jl Audio Car Audio & Video
XA10002 dual channell amp pushing a single 12 inch JL Audio sub and continues to go into protection mode. All setting are turned to the lowest possible and remote wire, power wire, and ground wire are all...
Make sure you are wiring the sub to the correct ohm's. Some amps have a protective feature that will send them into protect mode if they do not since the right ohm load. If the sub is wired correctly double check your ground wire on the amplifier, and if that if also fine then your amp will need serviced.
May 31, 2011 | xXx XA10002 Car Amp
Trouble with jl amp
well start with. turn your hi pass completely off. Turn your bass boost completely off. Turn your input gain copletely down. and turn your cd player to about 3/4 of what you listen to it at. Then turn your input up until it starts to sound a little dirty(distortion) then turn it down a notch. set it at a 80 herz filter so it allows nothing over 80 herz to come through. I just installed one of these jl amps a week ago. 1400.1 and it made two kicker cvt's sound amazing just have to set it just exactly like i told you. it will hit tight as hell and loud and it will hit all frequencies way better.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
May 26, 2009 | Jl Audio 12W0 Car Speaker
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Whats better
i would go with rockford cause they under rate alot of there stuff so it is actually better than what they say it is and audiobahn over rates there stuff so its wors than thay say w3v2 12's can be purchased at pro car sterio in roseburg oregon you can get them online @ jl audio.com for about $125.00 for the 12's and $110.00 for for 10's
Dec 02, 2008 | Jl Audio 12W3 Car Subwoofer
JL 1000/1 turns off
Does the amp have a volt meter on it? That tends to be pretty helpful in determining if it has enough power. I had to run an 8 gauge wire from my battery to the amp to get enough current to power an audiobahn 6 channel 6601t, with a dual voice-coil audiobahn 12 inch eternal. In the summer mine hits a thermal protection unitl I roll down the windows and ventilate the car, but that does not sound like thermal to me. It could also be the wrong impedance for your amp/sub combo. If you are making these speakers distort, you should be deaf by now. a 1000 watt amp is no force to be reckoned with. Your sub is 1.5 to 4 ohms. I posted a link to where you can check if it is wired properly. If these are distorting, it sounds like you have these wired for the wrong impedance. There is no way you should be making this setup distort at all without blowing out windows. It could be that you need 2 batteries, or if you are a pro DIYer Get some A123 batteries from a dewalt product. They have insane discharge. But I would recommend just getting a new battery (see bottom link), and making sure you have a 4-8 gauge wire going to the amp. I know a lot about batteries, as I built my own EV, so tell me how you have these subs wired, and how you have the amp wired to the battery.
http://www.crutchfield.com/S-B5qDIPXbsfV/learn/learningcenter/car/subwoofers_wiring.html
http://akamaipix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
http://www.optimabatteries.com/audio_electronics/
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
Jl Audio 1000/1 Car Audio Amplifier Logo
100 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
