Question about Stanley Bostitch Air Nailer Trigger N60 Fn
I have a N60FN Bostitch nailer. It's loosing air
I have a N60FN Bostitch nailer. It's loosing air around the trigger guard. I suspect it is the trigger valve. 1. Where is it located and what are the steps of removing it.
2. I have found a TVA6 repair kit on the internet for much less than the Trigger Valve assembly. If the Trigger Valve goes out, what are the chances it can be repaired or should I purchase a new Trigger Valve Assembly?
Any help would be appreciated.
Thank you very much
    President:
  • Stanley Master
  • 1,383 Answers
Your nailer uses a trigger valve part # tva6 (or tva1, but use tva6) (cost about $20) and is sold at www.bostitch.com or ebay for generic. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body (Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. Note the two grooves on the side of the valve where retainer roll pins hold valve. Remember to insert the valve with these two groves aligned with path of roll pins. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Posted on Jul 08, 2010
Stanley Bostitch N60FN finish nailer only pops when the trigger is pulled.
replace broken driver, or if driver is not broken replace the oring on the driver piston
Sep 10, 2012 | Stanley Air Tools & Compressors
The spring in my trigger flew out. how do i put it back
The n60fn uses two triggers, rapid fire trigger (black metal) is pictued with your post and does not need a spring. Just replace the 3 mm roll pin that holds trigger to the body of the gun and you should be good to go. The other trigger is the white plastic sequential. The sequential trigger uses a fine spring between the trigger and centered on the tva6 trigger valve. Parts and breakdown at www.toolpartsdirect.com. Good luck
Aug 23, 2010 | Stanley Bostitch Air Nailer Trigger N60...
I have a Stanley Bostitch finish nailer n60fn its leaking air from the trigger and housing.Is this something that I can rebuild and if so where can I get the information on how to rebuild it?
The fix it replace the trigger valve. It is a 5 minute job and seems to be a pretty common problem. Bad news is they seem to run about $30. I believe the bostitch # is TVA6
Apr 04, 2010 | Craftsman Nailer Kit, Palm Air Driver
O ring for bostitch n60fn
What you need is part # ORK1 and you can order it online from amazon.com The oring kit is $16.25. And if you also require a trigger valve assy it is listed on the page with the oring kit. The trigger valve assy is TVA6. Any questions please post back.
Oct 11, 2009 | Stanley Tools & Hardware - Others
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Air is leaking around the trigger. N60FN. How do you replace it?
Yes, you have to drive out the pins. There currently is no rebuild kit. Depending on when your was built there are solutions though.
Carefully drive out the trigger pin first. Then the one retaining the trigger assembly. The trigger assembly is in there pretty good, carefully work it out. Once you remove it, there are two small steel pins holding it together. Remove those...careful there is a spring inside. You can see what's been compromised. Like I said, there don't make repair kits for these, but you can order a replacement assembly.
Good luck.
http://www.mastertoolrepair.com/n60fn-p-4155.html
Aug 04, 2009 | Stanley Bostitch N88rh Framing Nailer...
My N60FN is leaking from around the trigger, where can I purchase a re-build kit?
The whole trigger assembly must be replaced.
Jul 23, 2009 | Stanley Bostitch N88rh Framing Nailer...
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
LEAKING BOSTITCH AIR NAILER
you probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Dec 26, 2008 | Air Tools & Compressors
Stanley Bostitch   Air Nailer Trigger N60 Fn Logo
939 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
