Question about GPS
My driver side door is completely dead. I will not look or unlock either driver nor passanger side doors. Even though the lights on the locking button the window button and the mirror buttons rapidly light up then shut off! btw the passanger side works just fine
    President:
  • 1,561 Answers
Check the door wiring harness at the grommet between chassis and doors.
You will have to take the outside shell off (very easy), and then the inside door panel. if you are able to access this, check to see if any of the wires as gone bad, because the problem would only be cause by a bad wire on the unit side, if any, replace it.
Take care.
Posted on Jul 08, 2010
Opening the drivers door doesnt automatically open the passangers door
Some vehicle locking systems allow a single button press to unlock the driver's side door and require a second button press to unlock the passenger side door. Likewise, use of the key to unlock the driver's side door does not automatically unlock the passenger side.
Mar 25, 2014 | Dodge Stratus Cars & Trucks
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
Mar 14, 2014 | 2007 Chrysler Sebring Sedan
1995 ford futura doors wont lock
Inside the door is an electric motor that pulls the door lock down to the locked position, either the rod has come off to the door latch from the door lock motor or the motor has failed. Remove the door panel and check it for power when the button is pressed for the power locks, if it gets power then it is most likely the motor that is the problem.
Nov 01, 2012 | Cars & Trucks
When i unlock the car from the drivers side the passenger door stays locked. if i unlock the car from the pasenger side the drivers door stays locked cant figure it out?
You have a slave door electrical sysyem ... ie the drivers door is the Master door with a mechanical lock ,,, which sends an electrical trigger to All the other doors.... the passinger door does not have the trigger signal for the rest of the doors, but can operate via a Key .(or elec trigger from drivers door) So to recap Driver door (master (no motor) all others triggered by Drivers door . So dud passanger door motor. Good luck
Apr 08, 2010 | 1999 BMW 323 Series
The driver side door locks and unlocks but it wont open at all
Looks like the lock itself has a problem in this that's why it wont open or there's something that makes the door stuck even though you lock/unlock it, It's best to replace the side door lock immediately. or better check if there's any elements that are inside the side door that makes the door jammed.
Mar 02, 2010 | 2006 Buick LaCrosse
2000 Buick Lesbre - Intermittant electrical: Door
THE PROBLEM SOUNDS LIKE LOOSE WIRING CONECTIONS IN THE DRIVERS DOOR , BEST THING TO DO IS HAVE A LOOK OPEN UP DOOR PANEL AND CHECK ALL CONECTIONS, GOOD LUCK
Oct 22, 2009 | 2000 Buick LeSabre
Honda Civic 2002 keyless entry
inspect and or replace the drivers door lock actuator...
Apr 05, 2009 | 2002 Honda Civic
Jeep grand cherokee central locking system
If all the doors do not lock or unlock when using the passenger side switch, then the switch itself is probably bad.   If the passenger side switch locks or unlocks all the other doors except for its own, then the power lock solenoid inside the door is bad or jammed.  If it is jammed, try locking and unlocking the door manually while activating the switch to work its way free.
Dec 13, 2008 | 1996 Jeep Grand Cherokee
2002 door locks failed ford escape
Using a multimeter, check for voltage at the lock/unlock solenoid. Disconnect the connector and probe the unlock side with the other lead on a good ground. Hit the unlock twice and see if you get voltage. If yes, the solenoid may be defective or if not, you could possibly have a bad relay. Even though you can hear the relay, that doesn't necessarily mean it's completing the circuit. My car did the same thing and I ended up replacing the relay.
The lock side check would be the same.
Hope this helps!
Aug 31, 2008 | 2004 Ford Escape
GPS Logo
16 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
