Question about Compaq UPS T1500 UPS System
Red led on above batt sign what does this mean
    Genius:
  • 1,040 Answers
Seems like your Battery is very low. Try charging the battery for a few hours. If the problem persists, it maybe the time to get a new battery.
Like all batteries, UPS Batteries (that store electricity and let s you use it in case of a power failure) have a limited life. This life is averaged to be around 2 years. So in case your UPS has been in use for approximately that much amount of time, the battery is in a near death situation.
For instructions regarding replacing the battery, please refer to your UPS Manual.
Hope this has helped you... Please rate the answer.. Thanks...
Posted on Jul 08, 2010
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Hi, I have a Cobra 29 NW ST CB Radio and I was wondering something about changing the stock burnt out bulb to an LED. Does it matter which wire goes to the negative side of the LED and which one is the...
LED's do matter how they're installed.
Test your LED leads w/ a batt. first before soldering in you 29 board.
Look at you existing leads from you burnt out bulb. One red?
Then its your Pos terminal. when your LED lights up on your Batt. test you'll know which one is the POS/NEG legs. then resolder it into your board.
Mike
Dec 31, 2010 | Cobra 29 LTD CB Radio
How can i check if which need replacement my batt or my charger coz when i charge my batt the led lights on then after a while it turn of the led light then ill unplug it and plug it then still the same...
Power Source Li-ion Rechargeable Battery (LI-42B) Are you using the above battery?
Check the voltage to make sure it has enough as printed on the charger or the battery.
Alkaline rechargeables, or NiMH rechargeables, or other types of batteries don't have enough voltage or amperage as compared to Li-ion.
Jul 03, 2010 | Olympus FE-280 Digital Camera
Kuryakyn fuel/batt guage problem
check the earth lead connection.crossed leads,
Jul 03, 2010 | Harley Davidson FXSTD - FXSTDI Softail...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
What does a flashing red light above the ON button
the can icon on the front of a pc usually represents the hard drive - so therefore, the led flashing means the drive is reading ow writing at the time
Oct 14, 2009 | Sony VAIO PCV-V200G PC Desktop
Batt light flashes 4 red and 1 green over and over vostros laptop
Hi there. If your battery light is flashing 4 red and one green on the battery light indicator (as in the one next to the power and hdd led), then this is an indication that your battery is nearing the end of it's life, and it's time to get a new one. It will last a bit longer, depending on how much you use your laptop, but there will come a time when it won't work at all.
Tim
Apr 20, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Kenwood TK370N UHF FM HANDHELD RADIO
By keeping the PTT button pushed, if you get a rapid beep and the red led is blinking, sounds like a bad battery. Batt voltage is a nominal 7.5v. anything lower than 6.25v and the low battery beep starts. A rapid beep, and no red led blinking, an error in the transmit freq.
Mar 01, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Compaq UPS T1500 UPS System Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
