Question about Canon PIXMA MP520 InkJet Printer
Flashing amber light error/warning on canon pixma mp520
SOURCE: Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Posted on Mar 11, 2008
Tirzo
  • 94 Answers
SOURCE: Canon i965 flashing amber light
Your printer experienced a PrinterPlease try the following to resolved that issue:
1. Resetting the Printer
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.
Follow these steps to reset the printer:
Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2. Reseat Print head
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If those steps above are exhausted and issue still present printer may require service.
Posted on Jun 11, 2008
  • 421 Answers
SOURCE: 5 flashes amber pixma ip3000
5 flashes amber means the print head is not installed properly (error code 1401) or the EEPROM data of the print head is faulty (error code 1403 or 1405).
Make sure the contacts on the printhead are clean, re-install and try again. If this fails a new printhead may be required. You may be able to re-initialize the EEPROM by entering the service mode.
Posted on Nov 11, 2008
cene765
  • 787 Answers
SOURCE: Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 04, 2009
SOURCE: canon pixma ip1980 service error 6000
the ink absorber is full
Posted on May 12, 2010
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Feb 03, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Error message E 2 's flashing .. what should i do?
If the alarm light is solid amber E2 indicates a paper feed error.
This can usually be cleared easily.
If the Power light and Alarm light are flashing green and amber then the E2 indicates an error requiring Canon servicing might have incurred.. If after disconnection it reappears then it looks like a bin job as nobody on the internet appears to have any solution for this one and anything involving Canon would be as much as a new printer.
Jan 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
2 Lights flashing on printer ( green / amber warning ) - status 5B00
MP170 (5b00) Ink Tank Full Error
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push ON/OFF twice, quickly
5,power off and power on.
Try to do this step maybe this will help you solve your problem.
Nov 17, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Error 6500 on a Canon MP500
choy ada yg tahu printer canon pixma mp500 error code 6500 g y? please help me
May 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Error reading GA80 appears on screen for canon printer PRIXMA MP5
Hello Leslie,
Here is a link to the MP520 Support Page:
Canon MP520
Manuals and guides are available on the Drivers & Downloads tab.
Thaks for using Fixya.
Sep 01, 2009 | Canon Office Equipment & Supplies
My canon ip5200 flashes 12 times, n bottom feed light is on.
it is problem your printer is wast tank is full it is service error
Jul 14, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
5 flashes amber pixma ip3000 5 AMBER FLASHES PIXMA IP 3000
Try this link http://www.fixyourownprinter.com/forums/inkjet/27412
Stanr
Oct 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP520 InkJet Printer Logo
180 people viewed this question
old marine
old marine
