Question about Roper RAX4232KQ Top Load Washer
Where is the filter?
Where is the water filter on Roper RAX423KQ washer?
  • 5,911 Answers
There is no water filter on this model washer. If you are experiencing FILL problems, this is usually attributed to a failed or clogged water inlet valve. The following link explains how to access and/or replace the inlet valve on your washer:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
You need to also check the sediment screens (if equipped) on the fill hoses to ensure they are clogged or corroded with calcified deposits, debris or rust. Cleaning the screens by placing them in a 50/50 solution of distilled vinegar and hot water can dissolve most accumulations of any deposits.
If you are experiencing DRAIN problems, you may have a defective lid switch, or something lodged in the drain pump. Symptoms of a defective lid switch may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
If the washer attempts to spin at the spin cycle but still will not drain, the problem could be a failed drain pump, or something lodged in the pump impeller or drain lines. The following link explains how to access and/or replace the drain pump:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
If you suspect a drain pump issue, you WILL have to drain the wash tub. For a quick and easy method of draining the wash tub, it is adviceable to use a wet/dry shop and pull a vacuum on the drain line. If the water will not drain due to line or pump obstructions, place the vacuum hose directly in the wash tub basin. If you do not own a shop vac, you will have to bail.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement inlet valve for model number RAX4232KQ is 285805. The lid switch part number is 3949247. The drain pump part number is 3363394.
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Many of these parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. If my diagnosis is incorrect, please post back and elaborate on what your washer is or isn't doing. I hope this is helpful to you.
Posted on Jul 08, 2010
Roper washer schematics
Are you referring to the inlet screen on the water fill valve? Screen should not be removed, just cleaned. Screen prevents objects from entering and damaging the valve. This damage may cause an over fill condition.
Aug 30, 2014 | Roper Washing Machines
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Water is leaking on to floor checked all
Does the machine have a filter that needs cleaning at the bottom front of macine
Jun 06, 2009 | Roper RAX4232KQ Top Load Washer
No cold water will enter machine but not water
Turn off the cold water.
Remove the cold water hose from the washer. Clean out the filter screen in the water valve. Re-attach the hose and turn the water back on. If you get no cold water replace the water valve.
May 01, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
ROPER TOP LOADING WASHING MACHINE
Check the lint filter at the end of the hose. The filter is actually inside the washer. My husband cleaned it out and now ours works great. Both hot and cold had stopped running in because of our hard water.
Sep 20, 2008 | Roper RAS8445KQ Top Load Washer
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
66 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
