Question about Garden
My aquatek 110 power washer keeps cutting out. i have only used it three times and was carefull not to allow it to overheat. the filter is clear, as i checked this as recommended in the user guide but it is still cutting out after about 4 minutes
  • 6,993 Answers
the aquatek 110 power washer has an automatic cut-out for protection function. So its cutting out because its protecting the washer from one damage or the other.
From the look of things, the power washer is faulty, that's why it keeps cutting out.
Take care.
Posted on Jul 08, 2010
Why does my pressure washer cut out after a few minuets use ?
Solenoid points have dirt n them, or have been burnt at some stage, and the spring tension has weakened,
Out with them and replace with new set, if its a popular model, they are not too expensive, if its an odd brand, find the part number, 99.9% of the time, another breed will fit,
Aslo check fine filters ( more than likely nylon ), for dirt or gunk,
If the washer is being used from a deep well bore, heavy minerals
can block filters...if this is the case, make a solution of hydrochloric acid & water, about 50%, even weaker, wear rubber gloves & eye protection, ( this is a must) , keep children at bay and just use common sense, this will 100% remove any mineral deposits and leave the nylon intact,
Also check for spiders, small frogs 'The Mud Wasp', 99% of the time a visual inspection will tell you , Always unplug if its 240V (Australian) ( 110 ? American ) . you will know that,
Also check for leaks,
If the pressure washer is electric or petrol or diesel, the pressure points work on the same principal
Hope this helps
Regards K1PA
Jun 15, 2015 | Garden
Jam with a cardboard from check book
On most Fellowes ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 27, 2013 | Fellowes (R) OD1500C High-Performance...
1994 ford galaxy 2.3 ohv problem cutting out
More than likely it is a FUEL PUMP that is failing or a Clogged Fuel Filter.
When the pressure is releived, the sediment will settle and allow you to start again but then get blocked again and repeats,,
Apr 08, 2013 | Cars & Trucks
What is Error Code F21
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 24, 2013 | Washing Machines
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
I keep getting a code "SL" on the display. Before this happens,the washer will stop counting back at 26,and seemingly try to go through the same process a few times. What is the problem and how much might...
Error code "SL" is displayed if suds are detected but the machine is unable to clean it out after three tries with a mini-cycle. This may indicate a bad pump, an extra heavy load, or inappropriate detergent is used.
Press STOP/CANCEL button to clear the display. Do not overload the machine and use a high efficiency (HE) detergent. Use 1/2, or even lower, of the normal amount if regular detergent is used.
The drain pump assembly price ranges between $110 and $130 exclusive of service fee if you ask a technician to replace it for you. Please advise me if the error code still appear on the display for the drain pump troubleshooting and replacement procedure.
Jan 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My dryer cuts out after a very short time and the
The filters may be clear but is the exhaust blocked or obstructed in any way? If there's an exhaust hose then also check that it's not been crushed or restricted by any sharp kinks in it's run.
Something is certainly causing an airflow problem as it's causing the machine to overheat and cut out.
I'm unfamiliar with your exact model, but I've found that some dryer designs are also prone to getting a restrictive build up of dust or lint in places the designers never envisaged and to clear those kinds of blockages I've successfully used vacuum cleaners set to blow or **** as needed and in the worst cases have needed to partially dismantle a machine to clear out the obstruction: you'll be surprised what can end up inside if you have children or pets...
Oct 07, 2009 | Dryers
I need instructions on replaceing the motor coupler on kenmore washer series 80 mod 110-24822200 typ 111
First you'll need to unplug the unit; after which I'd shut down the water supply and remove these. If against a wall you'll need to move the washer 3-4 feet from it to allow you to tip the washer back. No reason to lay it all the way down just on a heavy angle so you can access the under belly (be certain it will not come back down on you) I expect there is a noise shield you'll have to pull from its tabs. After which you should have a clear view of the motor and see where the remains of your older worn coupling are. I believe on that unit you'll unplug the motor (look for an electrical connection) then there should be two (2) pieces of metal that act like heavy snaps holding the motor in place, using a screw driver or such "un-snap" these pieces (be careful as once there loose the motor is too) this will allow you to drop the motor and gain full access to the coupling. This job should take @ 30 -45 minutes, take your time, keep it clean, keep it safe and in doing so you'll have saved you some good money.
I hope this may have helped,
Tom
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
