Question about Jenn-Air 24 in. JDB1250 Built-in Dishwasher
My dishwasher was working fine until yesterday when it refused to start. All the other lights on the panel will turn on, but the start button won't work. I've tried holding it shut to see if it's a latch problem but it didn't work... Any suggestions?
Hi, I have the same problem with my Jenn Air JDB 1250 model. I am wondering whether you have found a solution?
Posted on May 17, 2011
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: My dishwasher won't power on. Checked breaker and
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the RINSE ONLY button and hold it for 15 seconds, if it's still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 13, 2011
I am getting a 5H in the panel where the time cycle usually is and when I hit start it won t start
I think your dishwasher is in delay start mode. Some dishwashers can be set to start at a later time say for instance while everyone is sleeping. See if your control panel has a button that says delay start. If YES--just keep pressing it until it clears. Some go as high as 12H which is a 12 hr delay.
Feb 28, 2015 | GE Dishwashers
Dishwasher won't start
The technicians data sheet is attached to the bottom of the machine behind the kick panel.
May 21, 2013 | Dishwashers
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Wont' turn on
Push the "Heat Dry" button for at least 5 seconds. After that you should be able to start your dishwasher. The owner's manual I have says nothing about this, but this is a "lock panel" feature for the electronic panel design dishwashers. I just had this problem and stumbled upon a service manual online. Saved me $75.00.
May 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Sep 30, 2007 | Maytag MDB7100AWB Dishwasher
Jenn-Air 24 in. JDB1250 Built-in Dishwasher Logo
354 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
