Question about HandHeld Entertainment AvMap EKP-IV Aviation GPS
I put power on in ekp iv its say device not present. Please verify. ????
Asus maximus iv gene z error code 45
A Windows Error code 45 will display or populate a error message that looks similar to the following:
Currently, this hardware device is not connected to the computer. (Code 45)
The device is not present or was previously attached to the computer. If Device Manager is started with the environment variable DEVMGR_SHOW_NONPRESENT_DEVICES set to 1 (which means show these devices), any previously attached (NONPRESENT) devices are displayed in the device list and assigned this error code.
What is the solution for this then?
To fix this problem, reconnect this hardware device to the computer.
No other resolution is necessary.
Visit also asus, and look for any driver updates for the mainboard:
http://www.service.asus.com/#!downloads/c1wax
Good luck
Jan 24, 2013 | Computers & Internet
How to update Amap EKP IV. I downloaded a zipped file to the computer. In the zipped file are two files that match files on the compac card. If I move the zipped file to the compact card will the GPS do...
In order to update your EKP you need a CF reader, you cannot update your CF without it.
First of all download and unzip the update files from our support section.
Enable the show of hidden files. Create on your Desktop the folder 'Old CF'
and copy in it all the files from the CF (is the backup folder if something goes wrong).
Omit to copy the 'CHARTS' folder. Create on your Desktop the folder 'New CF'
and copy in it the same files you copied in 'Old CF'. Replace the files format swx
in 'New CF' with the ones you downloaded from internet. Ovewrite the files in the cF
with the ones in 'New CF' (do not touch the CHART folder). Turn on the EKP and verify
if the procedure was correctly executed. If not, reinstall in the CF the files from
'Old CF' and repeat the procedure.
NOTE! : this procedure can delete all user marks from the RAM. Save them first in the CF
with File Manager.
NOTE! For the update of 21/oct/10 you will need to update the Jeppesen cycle to !
Feb 06, 2011 | HandHeld Entertainment AvMap EKP-IV...
Phone off hook message
hi,
The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time.
f a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
Jun 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Avmap ekp iv
Hello weertobal,
Where are you using the GPS when this is happening? In order to get a fix on its own location the GPS receiver needs to receive telemetry information from four or more GPS satellites. In order to get this data, the receiver needs a clear view of the sky.
If you are using the GPS indoors, in an area with a lot of obstructions such as mountains, trees or tall buildings or in an automobile or vehicle without an external antenna, then your GPS may not have a clear view of the sky. This can cause it to be unable to get a fix on its own location or it may take a very long time to aquire a fix.
If the problem persists when you are using the GPS outdoors with a clear view of the sky, then this may be a sign of a more serious problem that could require service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | HandHeld Entertainment AvMap EKP-IV...
Acer Aspire laptop not producing sound
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices.
Good Luck, Please dont for get to Vote, Thank You.
Dec 23, 2007 | Acer Aspire 5674WLHi (LXAE10J008) PC...
The screen shows an error and says "Device not Present.Please verify."
DO YOU HAVE TOM TOM HOME INSTALLED ON YOUR COMPUTER??
LET ME KNOW
I HAVE A 910 ALSO I CAN HELP YOU
Dec 08, 2007 | Tomtom GO 910
Cobra 4000
Plug the unit it and leave it plugged in for a while, make sure to keep it off.
Let the power stay on the unit for a while, like 20 mins or so and then try it again.
I think that the unit has an internal battery like your alarm clock and when the power goes out the battery takes over. I beleive in your case the battery may be dead.
The same thing happened to mine.
Let me know.
Oct 17, 2007 | Cobra 4000 GPS Receiver
My laptop sound
Hi go to the manufacturers web site and download the "Sound" driver for your exact type of Lappy...
Sep 17, 2007 | Computers & Internet
HandHeld Entertainment AvMap EKP-IV Aviation GPS Logo
49 people viewed this question
Top HandHeld Entertainment GPS Experts
Are you a HandHeld Entertainment GPS Expert? Answer questions, earn points and help others
