Question about Kenmore Elite HE4 Electric Dryer
Igniter does not come on.
Dryer turns on and tumbles. It has propane going to it but it never heats up. Upon removing the front panel and watching it run the igniter never glows. Is this a faulty igniter or do I need to check something else?
  • 171 Answers
Most probably a faulty ignitor.  check the thermal fuse also.
Posted on Jul 28, 2010
Tumbles but no heat, how do i check out the igniter?
Some dryers have an access panel below the door. If there is a panel and you can remove it, you will be able to observe the igniter. Turn on the dryer so it begins tumbling and demands heat. A good igniter will glow long enough to heat the thermocouple and turn on the gas valve (click). Igniters are rather delicate and can crack with age but newer ones are less likely to do this.
Apr 23, 2016 | Dryers
Flame on dryer goes on off
see this causes and use the common sense.God bless you
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. To determine if the igniter is burned out, watch the part testing video at the bottom of this page. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Sep 19, 2012 | Frigidaire GLEH1642DS Front Load Stacked...
The dryer runs, but there is no heat. Gas is
Igniter
Gas valve coils
Thermal fuse
Aug 20, 2009 | Kenmore 700 6972 Dryer
Gas dryer does not stay hot.
Hello. I can help you. Here are all of the possible problems
Igniter
Gas valve coils
Thermal fuse
Jul 04, 2009 | Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
No flame but igniter cycles
Igniter
Gas valve coils
Thermal fuse
May 28, 2009 | Dryers
Dryer turns on and spins, but will not heat and dry clothes
Here is a quick course on the reasons why a gas dryer won't heat. If you are not mechanically inclined you will have to get a repair man because none of these reasons are quick fixes.
Igniter
Gas valve coils
Thermal fuse
May 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat in dryer
May 11, 2009 | Dryers
PROPANE IGNITER
I have never seen one go bad because of a dryer. I would call heating companies in your area and ask them to sell a igniter.Have the brand,model and serial number for the heater. You could get one off the Internet to. I would pull out the igniter and make sure the screw is tight and that the deflector doesn't it the igniter
Apr 17, 2008 | Coleman Propane Forced Air Heater...
Kenmore Elite HE4 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
