Question about Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Intermitant fault, take key out put back in then all is well for a distance ,then it slows and beeps 7 times any idea`s would be helpfull,
  • 177 Answers
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
  • 1 more comment
  • kenhesket924 Jul 09, 2010
    Hi GURU. thanks for your reply, have ordered a new pot and hope its not to difficult to fit.
    Best Regards KEN
  • Bruce Swarts Oct 23, 2012
    I have the samething with mine. Replaced the speed pot and the Throttle pot ! still seven peeps ? Any ideas
  • Bruce Swarts Oct 28, 2012
    I turn it on and get the seven beeps. Shut it off and turn it back on and it runs untill you let off the throttle ?
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
Why did it shut off and begin beeping?
These beeps are fault indication (Error Codes). From the number of beeps occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called beeping codes. Make sure about the exact number of beeps. , by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about beeping codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
May 27, 2015 | Emerson Televison & Video
When I want to get scooter to go, it just beeps.
2 beeps=too low battery voltage
3 beeps=battery voltage too high
5 beeps=solenoid brake trip or free wheel mode
remove key then push then push the manual release lever in completely
6 beeps=throttle trip
throttle control lever may have been depressed while
inserting key so release control lever completely
7 beeps=throttle trip
throttle potentiometer fault or speed potentiometer fault
Oct 01, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
Why does it constantly beep?
hi, it's it's running okay but bleeping , could be low battery voltage or a failure in the bleeping circuit with wiring or the controller...
Regards
Rob
www.gewzirepairs.co.uk
May 03, 2014 | Pride Mobility Products GoGo Elite...
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Beeps 7 or 8 times and stalls. turn key off and back on and it runs
hi, 7 bleeps is the throttle pot , most likely it is worn, or miscalculated...depending on model , the newer one's use a self contained unit so no calibration is required however will fail when the voltage gets too low,,, , I suggest you check the connections to the controller as they can be a source of problems...from the throttle to the controller....
Regards
www.gewizrepairs.co.uk?fixya
Oct 08, 2013 | Pride Mobility Products Go-Go Elite...
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter  Logo
2,075 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
