Question about Pioneer DVR-107D DVD±RW Burner
Pioneer device (Pioneer DVD-RW DVDRKDO8A an ATA device installed on my Toshiba A 300 does not work anymore. What's wrong
  • S.John Bekkering Jul 08, 2010
    For one thing, my CD/DVD player is build in to my laptop Compter (Toshiba A300). It is impossible for me to take that out. Now what ?
  • 4,737 Answers
There are several reasons for your dvd writer being stopped working. It could be your Laptop or it could be the Dvd writer itself. So let's try some troubleshooting measures to find out the root of the problem.
*[Requirements; one extra working ata/ide dvd writer; another laptop with ata/ide connector for cd/dvd writer; soft brush, alcohol/acetone/spirit]*
First of all, let's get started with the Dvd writer; Remove the Dvd writer, clean the interfaces (connectors) using soft brush dipped in alcohol or spirit or acetone. Also clean the Ata connector on the Laptop. After they are dried, reinstall the Dvd writer on the slot and power on the Laptop and check if it's detected in the Bios or not. If it's detected, boot it into normal mode and check again. If you can see the drive in the My Computer, then you need to check whether it's reading cds/dvds or not. If it's not, then you need to try different cds/dvds and make sure any cd or dvd is working or not. In case none is read, switch off the Laptop and remove the dvd writer, now install it on the other laptop. (if you don't have another laptop with ide/ata connector for cd/dvd rom, you will not be able to perform this). No positive effect?, your only option in to replace it.
Doesn't the Bios detect the Drive? then install it directly on the other laptop, if its detected there and works well, then the problem is with the interface on the Laptop which you'll need to take it to a service center.
Now let's check the system. It'd be better if you had mentioned the operating system installed on your system. Many Windows 7 users are facing this problem because of Raid driver problem, as we know many hardwares and softwares aren't compatible with windows 7. In this case, the Bios will not detect the Cd/Dvd rom and when the computer is booted, it'll not show up on the My Computer or In the Device Manager.
Well, you might get confused, let me wind up here for now. Please let me know when you are done with the above mentioned instruction and if the problem persists and your system has windows 7 installed on it, let me know so that I can help you check the Raid settings and Drivers' signing problem.
Good luck.
Thanks for using FixYa.
Posted on Jul 08, 2010
  • Lebanon Raingam
    Lebanon Raingam Jul 09, 2010
    Yes! You can say it's "built-in" but in fact it's not soldered on the motherbaord or on the case, instead it's mounted on it's compartment which can be easily dismounted/removed after loosing the screws from the back. Please do check it carefully, most new laptops don't have even either screws on it, but a clip-lock which when pressed released itself. [I can't find your dvd writer's exact model online with features so I can't assume and make you specific on this]
    If you are having opening this, please don't do it, I don't recommend "do it yourself" method and you know, it can lead to permanent damage to other components if it's done wrongly without proper knowledge. I would rather suggest you to please call a Technician or a friend who has ideas opening/removing the dvd drive and let him/her try it for you. But if you know what you are doing and sure you can, then go ahead and let me know the outcome so that I can assist you better and further.
    Good luck.
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
manually download it from the pc makers website drivers section and point the driver setup to the folder.
Nov 09, 2008 | HP Pavilion dv6000z Notebook
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer dvd-rw dvr-k17a
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
Dear Sir/Madam,
This is the problem of not matching/support the motherboard of your driver with Pioneer DVD. U just go the manufacturing site of Pioneer dvd and download the driver / updates and then install it. (Before u uninstall the driver). Then fix it.
Thanks
"Don't Forget To Rate the Solution"
May 19, 2008 | Computers & Internet
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
PIONEER DVD-RW READS ONLY DVD BUT NOT CD
The CD laser has got dirty or failed
Try a driver cleaner if that does not work
replacement drive required
Nov 18, 2007 | Compaq Presario Notebook
Pioneer DVR-107D DVD±RW Burner Logo
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
