Question about Epson Stylus C48 InkJet Printer
The print head failed to move to the ink cartridge position when trying to replace the ink cartridges
jdrrwoods
  • 82 Answers
SOURCE: Ink cartridge not in place - now it's stuck
turn it off and pull it over manually
Posted on Feb 09, 2008
  • 6 Answers
SOURCE: LCD message: CHECK INK TANK
Please check the solution posted in this
http://www.fixya.com/support/t145742-printing
I'll think of something
Posted on Feb 05, 2008
SOURCE: Black 3ek cartridge not printing
I had the same problem before with 3e black ink. It simply does not print too, so what I did if i get to print black and white i will set the characters into dark gray! it looks like draft printing but the things is it can be printed.. I tried to do every instructions available but to fail. I almost dump it till I decided to set it aside for a while. After a week I tried using it again, and it functions well. I guess the printer just want to say, "HEY BUDDY, GIVE ME A LITTLE BREAK!"
Posted on May 15, 2008
SOURCE: Canon MP530 print head malfunction
Do you mean the thing that holds 5 catriages? Sometimes, I keep it in the center by hand.Of course, you do not need always hold it. Once it stays, you can move your hands and replace catriages.
Posted on Feb 24, 2009
SOURCE: Epson printer: print head not moving to replacement position
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Posted on May 23, 2009
How do I change ink cartridges for Epson DX4450
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Jun 07, 2011 | Epson Stylus DX4450 All-In-One InkJet...
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
How do i get the cartridge out
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
How do I change the ink cartridge?
You are now ready to print.
Oct 18, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Printer Wont print even with new ink
that means, 1 or more of the carts is showing low on ink or it might not being recognized. it might be the ink has a problem or the printer has a problem that it cant recognize the ink. try to Remove and reInstall Cartridges,
Press the nx200ug.1.106.4.jpg Stop button. The print head moves to the nx200ug.1.106.5.jpg position to indicate which cartridge is low or expended. Press the nx200ug.1.106.7.jpg Stop button again. If another cartridge is low or expended, the print head moves to the nx200ug.1.106.8.jpg position. Press the nx200ug.1.106.9.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. once you've identify w/c color has a problem, and removing and reinserting it does not resolve the issue, try another ink of that same color, if the issue persist, that means the printer is broken, call epson to get a replacement printer if it is with in 1 yr. from the date of purchase
Sep 15, 2009 | Epson Stylus C88 InkJet Photo Printer
How to change ink on epson dx4450
The steps are :-
Replacing the cartridge:
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Office Equipment & Supplies
Epsom dx4450 how to change ink cartridge
Sep 16, 2008 | Epson Aculaser C1100 Printer
Epson Stylus C48 InkJet Printer Logo
778 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
