Question about LG Dishwashers
Why is my dishwasher flashing LE - LG Dishwashers
  • 5,081 Answers
This is very common problem with LG dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem.
Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Posted on Jul 08, 2010
  • 3 Answers
CHECK THE WIRES CAREFULLY. I missed it the first time around. it was a blue one stuck in the black insulation.
Posted on Oct 26, 2011
Door on diswahser not shut completely during cycle. water leaked out onto floor. now flashing LE and cannot power off or on.
Good picture! The LE message indicates a leak, but besides leaking on your floor, apparently some water has gotten into the base and triggered the water-leak sensor. Basically, that water must all be sopped out dried out, then the message will go away by itself. You will probably have to pull the dishwasher out to be able to get to the water in the base.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 05, 2015 | Samsung Dishwashers
I have a LG dishwasher, and from the word go I've had problems, I try not to use it any more. it started with flashing LE and bing bing bing all the time, now it flashes HE, I think its time to throw...
the le code is motor code the motor is not turning the he code is heater code if the motor is locked it will also bring up the he code because the over stat on the heater will cut out because the water cannot circulate
Oct 25, 2011 | Dishwashers
Le keeps flashing
le code is a motor error either you have a broken wire between the door or the motor is bad
May 12, 2011 | Samsung Dishwashers
A screw fell inside the tub I took the bottom sreen apart it was uder the base were the impeller is, took that apart, put everthing back together and went to start the dishwasher up and the LE code...
try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE problem.First disconnect all power ( power supply, circuit breaker, wiring etc) to the machine. Disconnect all tubing to the machine ( drainage pipe and braided hose feed) Then you need to take out the dishwasher, turn it over and then remove the large white sensor tray that will expose the leakage sensor held on by 2 screws. Remove the screws and dry up the sensor tips (4) with a dry towel and dry up the tray all around as well. Replace the tray and re connect all tubing and power. You're problem should be solved and you just saved yourself a pile of money in service repair bill. M.D.
Dec 22, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Clean light flashes 7 times then repeats
Bonjour,
ma machine à laver la vaisselle., Maytag, le modèle S-MDB9600AWS PLASTIQUE éclaté sur les deux roues tiroirs connectés navires. Où puis-je acheter ces roues et ce que nombre d'entre elles ont?
Merci,
Aug 17, 2009 | Kenmore Dishwashers
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
273 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
