Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Briggs and stratton 24 HP model ELS 725 mower stopped running have power, turns over, does not fire. please explain your answer with instructions for ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING
  • ifixemtorun Jul 11, 2010
    Briggs has gone with a plastic needle valve in the carb that is not heavy enough to drop out of the seat. Remove the fuel line from the pump outlet going to the carb. Apply about 30 psi blast of air to the line you took off the pump, this will dislodge the needle from the seat and allow fuel to flow into the carb ... GAS JUST AINT WHAT IT USED TO BE and a lightweight needle valve didn't help matters
    Sniper:
  • 56 Answers
A great expedient spark tester can be made from an old spark plug that you know is GOOD.....clip or grind the grounding terminal ( the terminal which goes over the top of the electrode) back until you have a gap of 1/8 to 3/16 of an inch between the terminal and the electrode...Remove both plugs from the machine and attach your new test plug to the plug wire. Ground the plug by placing it on the head or the shroud. Turn the machine over. If you are getting fire you should see a strong blue spark shoot from the electrode to the terminal. If you have no fire then you probably have a bad ignition coil, bad plug wire, or maybe just a bad seat, brake, or PTO safety switch...I'd check these first. Also check your ignition switch in the run position with a test light to be sure it is good....hope this helps... ;-D
Posted on Jul 26, 2010
Briggs and Stratton 24 HP ELS engine common cause of vacuum leaks causing engine to run poor
im not sure on an answer but i do know 200 lbs is way too much compression. go to a good lawn mower shop and talk to service. they should be able to give you a direction on this problem
Jul 25, 2013 | Cub Cadet Garden
Kubato 1760
Hi karen. Your not explaining what you have done to get the mower going. All petrol mowers run with three problems. Fuel,fire and air. If you are getting all three it will either be a snapped Piston or the gaskets on the block have perished. Check eHow's website and follow the instructions. Good luck
Jul 05, 2013 | Briggs & Stratton Briggs Stratton...
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Have a 22 ohv B&S els 725 v twin want recharge a new battery
If you want to recharge a "new" battery you should use a trickle charger and leave it on over night. Remove the ground side wire from the battery before charging. let us know
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
664 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
