Question about Symbol LS2208 Handheld
I have installed com port emulation driver for motorola LS2208 symbol scanner.now how to get scanned codes through serial port to my vc++ application? pls help
    Scholar:
  • 117 Answers
You would need to setup the scanner to communicate in proer way, please use the barcode "Simple COM Port Emulation" from the Manual here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=189660311&stateId=1%200%20189654341
Posted on Aug 27, 2010
Wher can i found Simple COM Port Emulation USB driver version 1.8.6
Have your tried the driver provided at
www.driverscape.com/download/symbol-usb-com-port-emulation
It says tis 2.33mb. Even if it turned out to be a driverscanner, simply install and wen it find the driver you are looking, use the ID to search for it on google and if it can installed directly.
Good luck
Nov 14, 2014 | Symbol LS2208 Handheld
How do I get my Symbol LS2208 to recognize EAN128. I need it to prefix [C1 when a EAN 128 is scanned.
you need to scan some of the bar codes found on the manual.
Find the product reference manual -usually found on the cd with the scanner or download from motorola site - and in chapter "symbologies" scan "ENABLE CODE128" barcode.
To have prefix when a code is scanned, scan "SCAN OPTIONS" then " then "ENTER"
Last set the preffix value by scanning "SCAN PREFFIX" then four digits that correspond to the character you want to use as preffix.
If you need more than one character for preffix then you will need the Advanced formatting manual, which ican be downloaded from motorola. In this case you need to create a "rule".
Let me know if you need further assistance
Nov 11, 2010 | Symbol LS2208
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
I have a telxon ptc-610 and a new symbol LS2208 and can't get it to scan? Do I need to program?
Hello swschmidt. You are spot-on! You need to do a wee bit of configuration. I host he LS2208 manual on my company site for my clients (www.shiftintoblue.com/resources/ls2208_manual.pdf). Head to page 146: "Wand Emulation Host Parameters". Print that page and scan the 'Symbol PTC Terminal (Telxon)' barcode and you'll be all set. I hope this helped. Good luck!
Jan 08, 2010 | Motorola Computers & Internet
Can't get my computer to communicate and update the Symbol LS2208 barcode scanner.
When you scanned the "set defaults" barcode in the manual, you erased all "host parameters". Find the appropriate HOST barcode and scan it. That should establish communication with the host (Keyboard Wedge, USB, Serial) If you are having issues, contact the Motorola Help Desk at 1-800-653-5350 or me at 1-866-306-7226
Bill Matisz
qdata inc.
Oct 27, 2009 | Symbol LS2208 Handheld
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Oct 06, 2008 | Computers & Internet
LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Oct 06, 2008 | Symbol LS2208 Handheld
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Symbol LS2208 Handheld Logo
1,297 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
