Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool single self cleaning oven, model # What I need now is a parts source for the control panel and temperature sensing unit here in San Antonio TX. Additionally, I need part replacement and maintenance procedure instructions to do the job.
    President:
  • 1,561 Answers
I would advice you follow the link below to see the information therein, the link contain information as regards the the issue above.
file:///C:/Documents%20and%20Settings/Jimoh_1/Desktop/Range-Stove-Oven-Troubleshooting.htm
Type the above information to see information therein, and as regards the part you need for the replacement, i would suggest you order for you part from ebay, the ebay site contain almost all parts of all device, within a very short time it is delivered once ordered.
Type ebay.com on your web browser to order for your parts.
Take care.
Posted on Jul 08, 2010
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Broiler element and oven element not working. oven has power to it, all lights and displays are working,
    Since neither the broiler or bake elements are working I would suspect either the sensor - sensing a higher temperature than set meaning the sensor is defective (Item #29 on the diagram) - http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Wall-oven-Parts/Model-YRBS305PDB5/1198/0125300/W0703198/00001?blt=06&prst=&shdMod=
    You might try the self clean function and see if the elements get hot. If they do then it is most likely the sensor.
    Hopefully, that will fix your problem, but if not then it could be in the microcomputer which is a problem because it is a part that is hard to find.
    Sep 04, 2011 | Whirlpool RBS305PD Electric Single Oven
    Whirlpool Oven will not heat
    Hello there:Usually,
    when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
    Jul 22, 2010 | Whirlpool RBS275PD Electric Single Oven
    I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
    Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
    Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    F2 error
    HI, the oven control has sensed a very high oven temperature during baking or cleaning.
    SOLUTION
    1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
    2. For SELF CLEAN models: check door lock operation.
    3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
    Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
    Oct 08, 2009 | Whirlpool Ovens
    Oven does not work after running self cleaning
    Dear Dupe,
    please rate this solution if it mends up ur needs,else choose fixya,
    please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Dec 17, 2008 | Whirlpool RBS305PDS Electric Single Oven
    How to remove the control panel on Whirlpool double oven Model RBD305PDS14
    Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
    Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
    Oven wont work after self clean
    I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
    Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
    Whirlpool Accubake oven super capacity series 465
    In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
    Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
    F2 error message
    Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
    Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
    Whirlpool RBS275PD Electric Single Oven Logo
    18 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
