Question about SanDisk 1GB Memory Stick M2 Memory Card
Pleeze help, ok i insert my memory card reader and computer recognises, fine, however when i insert my 16gb sandisk m2 memory card.....nada, nothing, zilch!?? It says that there is no media inserted and now its driving me nuts!! any suggestions?
    President:
  • 1,932 Answers
This is because there is a fault in the slot where you put the memory card.
The problem is the memory card contact surface in not in contact with the memory card reader contact surfcae.
So please change the memory card reader it wil be fine.
Thanx
Posted on Jul 23, 2010
My computer won't recognise my sandisk card reader D33D21? Are drivers available for this on windows 7?
You should not need drivers. Chances are that the drive died. I would try putting this device in another computer first. see the results. The wear leveling mechanism on most of these drives is limited; and it will start "not working" when it's reached the end of life. A professional data recovery company can get it back usually. http://techrxgb.com
Jul 23, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
I try to format my M2 memory card on my computer,
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Apr 02, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
How to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
Dec 05, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
I have 1gb m2 memry card for about a year it
this happens dude.
try to format it using a memory card reader on a computer, sometimes the card get corrupt
format it, it shld work fine, u can copy ur data also on the computer for a backup.
Nov 02, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
My sandisk m2 does not get regognised on my mobile phone.
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Have a great day!
Aug 16, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
The memory chip is not being found in the phone
The Memory Card Had Damaged You Need To Replace It.
Mar 31, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Gud evning sir my m2 memory card first worked well in my w200 mobile suddenly my phone i not recogonize or read the memory card but if i put another mmc it reads wats the problem in mmc how to solve pl...
vivek,
try to insert your m2 memory card to other card reader device and check if it can be recognized. then scan for possible virus infection or reformat your m2 memory card.
if still no change, clean the contact pin from your m2 card. use metal folish liquid solutions to clean the copper contact pin of m2 card.
cheers,
mark
Feb 01, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Broken m2 card
Try to put the memory card into the card reader of any system. If nothing comes, your memory card has some problem and is better to get it replaced.
Thank You
Oct 25, 2008 | SanDisk 1GB Memory Stick M2 Memory Card
SanDisk 1GB Memory Stick M2 Memory Card Logo
240 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
