Question about Samsung CLP 300 Laser Printer
CLP300 Print Alignment Problem
Printer increases top margin of text document printed on A4 portrait by 11mm, moving text down on the paper and even off the paper at the foot of the document.
Problem is random but frequent with Word, Excel, Coreldraw and other programes
System used is Windows XP Pro using latest printer driver on P4 Intel PC with max ram
Resetting to default, re-loading drivers, re-installing all makes no change - it keeps on moving the printed area down on the paper
5 Suggested Answers
SOURCE: Printer gets stuck with a "Printing ..." or "PC Print ..." message on the LCD display
I have the same problem with mine. Another option is to "Log Off Administrator" at the PC or "Restart" the PC and prior to shutting down it seems to pfrint all my jobs ... better than cancelling.
Posted on Feb 01, 2007
SOURCE: printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Posted on Dec 03, 2007
SOURCE: Samsung CLP-500 output problems
i have found that removing the toners, and shaking them side to side, while keeping them horizontal, which seems to spread the toner for even distribution. This can sometimes fix the problems with fading prints. hope it helps.
Margins i think might be a problem with the wysiwyg of the program, some don't do it well, but also excel in particular has a shrink to fit page option, you may find the percentage not at 100%. you can also copy an excel table to word and print from that if it is driving you nuts.
Posted on Feb 05, 2009
  • 113 Answers
SOURCE: Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Posted on Apr 17, 2010
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hi, I am using ms word 2007 and need an a3 sheet format. Its not in the page set up drop down menu and the only solution I have is to customise my page size. Even doing this however, and increasing my...
The print sizes available are dependent on the printers installed.
If you don't have an a3 printer installed on your computer, there won't be a A3 option in word.
if you install a standard pdf printer like cutePDF(simulates printer, but instead of printing document on paper, it generates an adobe pdf-file from the document) the option should become available in your dropdown.
Apr 04, 2008 | Computers & Internet
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
Samsung CLP 300 Laser Printer Logo
75 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
