Question about Fisher and Paykel Washing Machines
Fisher & paykel washing machine (gw603-u) emptys while filling
My fisher & paykel washing machine (gw603-u) keeps pumping water out while trying to fill - seems to think that there is too much water in it perhaps? (never gets deeper than an inch or so)
I have pulled the whole thing apart, pump not blocked, out of ballence switch working, hot and cold water valves working, motor seems fine...
All I can think is it is the pressure sensor on the main board?
The other fault it has is that when you first power it on the first 5 led's flash - which Ithink it means that the thing is in ''restart off'' mode, but it wont remember setting it to on once you pull out the power plug (it does however remember changes to the preferred wash settings)
Any ideas?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now where is you machine draining to?Is it draining into the laundry sink or somewhere else?If it is draining into the laundry sink and not into a grey water hose then I am afraid it must be the green motor controller.This controller has the pressure switch as part of the circuit board.I think though it must be the fet that controls the power to your pump might be faulty.Are you in Australia as there are company's that will test your motor controller if you send it to them.Please reply with additional information and I can help you further.
Posted on Jul 09, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel washing machine excellence 6.5 smartdrive 8
see this possible causes: God bless you
see the diagrams
Lid switch
test for defective or open
Motor coupler
replace coupler motor for defective
Belts
worn belt
Clutch
wears replacement
Drive motor
one winding burn , run with one winding in one direction and another with the other winding.
Drive pulleys
frozen pulley, worn.
Transmission
broken gear+ shifter defective
Agitator
worn agitator replace
5_16_2012_7_59_29_pm.gif5_16_2012_7_59_43_pm.gif5_16_2012_7_59_54_pm.gif5_16_2012_8_00_26_pm.gif
May 16, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
177 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
