Question about Apple iPod MA446LL/A MP3 Player
Its stuck in disk mode screen displays a check mark that says ok to disconnect player wont turn off or go to menu screen
  • 85 Answers
Try resetting it. Hold down the middle and menu buttons at the same time and it should reset itself. Then it should go to the main menu. Good Luck!
Posted on Jul 10, 2010
Ipod 30gb its stuck in disk mode screen displays (dont not disconnect) hot to fix it plz.
Posted on Sep 08, 2010
My sansa m230 driver mp3 player is not detected as removalble disk i mean as a flash drive on my laptop how can i fix this issue
When you're able to change USB mode in the display:
- From the Main Menu, select Settings > USB
- Select in "Auto Detect", "MTP" or "MSC": choose MSC for viewing the player as a removable disk.
When you cannot select MSC mode in the player's menu, force MSC mode with the player switches/buttons:
1. Turn device OFF.
2. Facing the hold switch: slide it to the right so an orange color would show, putting the device on Hold.
3. Connect the device to the PC with the provided USB cable.
note
In MSC mode: Before disconnecting the USB cable always go through the safely remove hardware icon in the lower screen of your computer on the right. Left click the icon to see all removable disks and left click on the removable disk drive letter of the player to disconnect: after the message you can take out the USB cable.
Jul 03, 2010 | SanDisk Audio Players & Recorders
Canon PowerShot A450 as web cam
Please follow the steps below...
  1. Set the camera to Disk Drive mode (this step only needs to be done once):
    1. Turn on the camera, then press the Menu/OK button to display the Capture Menu.
    2. Use the Right arrow c00188560.gif button to navigate to the Setup Menuc00188561.gif .
    3. Use the Down arrow c00188562.gif button to highlight the USB menu option, and then press Menu/OK .
    4. Use the Down arrow c00188562.gif button to select Disk Drive , and then press Menu/OK .
    5. Use the Down arrow c00188562.gif button to highlight EXIT , and then press Menu/OK .
  2. After setting the camera to Disk Drive mode, connect the camera to the computer using the USB cable.
  3. The camera will appear as a removable disk in the Windows Explorer screen. You can now transfer the images or video clips to a location on the computer using Windows Explorer.
  4. When finished transferring images from the camera to the computer, disconnect the camera from the computer. If the computer is running Windows 2000 or XP, there may be an Unsafe Removal warning upon disconnecting the camera. This warning may be disregarded.
Feb 21, 2010 | Canon PowerShot A450 Digital Camera
I woke up this morning and noticed my IPOD nano silver 2GB displaying a disk mode pn th top of the screen with a huge checkmark in the middle of the screen and the phrase ok to disconnect on the bottom of...
Reset Ipod.
Make sure power switch is on.
Press and hold center button.
next press and hold "menu" on the ring.
When a Apple logo appears on the screen let the buttons go.
Should take just a few seconds.
May 04, 2009 | Apple iPod nano
Nano Ipod stuck in disk mode:
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 31, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Frozen iPod
move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Oct 23, 2008 | Apple iPod nano
Ipod
Whatever you do, do not disconnect it when it is like that. Do a reset (hold the menu and play buttons until the screen goes black and then quickly disconnect it from the computer.
what you do now depends on what the iPod does after you disconnect if from the computer. If the screen comes on, then you are OK. If it comes back to the do not disconnect screen, do a reset again, and this time when the screen goes black, quickly hold down the play/pause key and the middle key. Hold them until you see a check mark and the words, 'disk mode'. Connect it to your computer while it is like this and restore it. Hope that helps.
Sep 07, 2008 | Apple iPod MA446LL/A MP3 Player
Disconnecting player while in MTP mode
It is not designed to show up as a Removable Disk in MTP mode, therefore it wont show up in the Safely Disconnect Menu.
If you are using Windows Media Player to transfer, as soon as the SYNC is complete, it says "ok to disconnect". You can disconnect without any problems.
If you are using Rhapsody, or the Best Buy Digital Music Store, you can right click on the device in the Sources Menu and select Disconnect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
649 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
