FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
BABHMJ's dishwasher husband
posted by BABHMJ husbn on Apr 18, 2008
Tannerdis, I followed your instructions. The motor disc rotates freely. I see no valve in the hose, which exits the motor, then snakes around above the floor of the dishwasher, above the floor of the sink, and enters the side of the garbage disposal, which is old. The dishwasher seems to operate normally on the wash cycle. On the drain cycle, it does not drain, then quits. Removing the hose from the disposal shows a trickle of water being pumped out during the drain cycle, but not the flood expected. It ends when the drain cycle ends. The frame of the motor is corroded, but it seems to operate OK. Ideas? Could the drain or the hose be blocked? Is there a valve which shunts the pumped water either through the dishwasher wash syster or out through the drain? It might be stuck or broken. Can I find a schematic for the thing somewhere? Sears used to include an exploded view of their gear, with the components all numbered, and a numbered component list for that device, with it's respective part nuimbers, so you could order replacements. Where could I find such a thing? If I could understand how it works, perhaps I could fix the bloody thing in time for Sunday's feed.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 26, 2008
Not Rated (0)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 288 votes
You need to pull out the D/W so you can get access to the water pump and remove the hoses to see if its clogged.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
Water Stayed in dishwasher
Could you please advise why... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
my dishwashers not working
hi. when i put it on for a... Answer This...
WHIRLPOOL QUITE PARTNER ii
it just quit. no lights... Answer This...
clean light is blinking
clean light is blinking. Manual... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
