Question about Goldstar WG8000 Air Conditioner
Water not draining properly from ac .
I heard what sounded like the fan hissing looked throught vents can see water laying in case. cant find owners manuel to see what to do any help would be greatly appreciated. thank you
  • Goldstar Master
  • 43,501 Answers
Both are very normal...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
How can I solve a problem on my pc wiith regards to it's hissing sound
In most cases it sounds like the fan is having trouble. Get a can of compressed air and clear out the air vents on the sides and back. It may spit out a ton of dust, and it should help improve the hissing sound. If it needs a better cleaning, you may need to remove the lower part of the casing.
Aug 21, 2014 | Toshiba Computers & Internet
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
Our ac unit is making a loud noise and there is water coming into the house via the vents. we cleaned out the vent and took some of the water out of the middle pan and the outside pan, and it doesn't...
My recommendation would be to have some one knowledgeable in refridgeration come in and take a look. You make have more than one problem going on. However the water build up can be due to a plugged drain line. Try using a wet and dry vac to clean the drain line . the fan noise may be the fan motor bearings. If this is the case you can remove the fan and possibly have bearing installed but most likely will need to replace the fan motor
Jul 07, 2011 | General Air Tools & Compressors
2006 slt gmc envoy ac problems vent controls anbd
{: ) The popping sound you heard is caused by the sudden movement of an HVAC door, most probably coming from the recirculation door actuator (right dashboard area) or the mode actuator( mid dashboard area). The fan outputs could be normally working, but is being muffled by the incorrect positioning of the HVAC doors, giving an impression that there is fault in the blower controls. In other words, your vehicle is having an air distribution issue.
If there's no conflict in your climate settings, then the trouble may be in the HVAC doors binding or broken, or the actuators faulty or sticking. In both cases, servicing may involve removal of the dashboard to access these HVAC components.
Jul 20, 2010 | 2006 GMC Envoy
How do I clear the AC condensate drain on my 2008 CX-9?
The first place I would look is on the firewall from under the hood. Toward the passenger side, (I think) you should see a rubber nozzle coming out of the firewall. This is the condensor drain, and chances are of course, it's clogged up. You should be able to easily remove it. Upon doing so, the condensor should drain the collected water. Then, you'll have a good oportunity to clean the nozzle and put it back in.
I hope this helps you with your problem! :)
May 03, 2010 | 2008 Mazda Cx 9
My 96 thunderbird gettin hot
is your fan clutch kicking in? It could be bad. crab the fan blade and try to move it back and forth. If it moves more than minimal you will need to replace your fan clutch.
Oct 08, 2009 | 1996 Ford Thunderbird LX
Honda acac sometimes blows some kind of dew air throught he vents
u most likely have some condensation building up in evap box ,,need to clean it out before it gets worse,,,if u are running it on low blower ,it is going to put out mist sometimes (if the air is really cold) because of the expansion valve pulling down the tempurature
Jul 06, 2009 | 1996 Honda Accord
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
2003 forester - there is water leaking in the front passenger side floor when the air conditioner is running. sometimes a hissing sound also in the same area.
You need to clear the condenstate drain for the AC evaporator core, it is under the car, as far as the hissing, sounds like a vacuum leak, look for a disconnected small hose around the area of the noise.
Aug 04, 2008 | Subaru Forester Cars & Trucks
Dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Nov 23, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Goldstar WG8000 Air Conditioner Logo
141 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
