Question about RCA E13344 13" TV
SOUND PROBLEMS WITH MY RCA E13344 - RCA E13344 13" TV
I have the same problem!!
Posted on Sep 10, 2010
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
My RCA E13344 Tv is connected directly to the cable wire (no cable box) on the menu i set the tv to cable tv and serch for the channels. After the serching is done the tv stops at channel 7 instead of...
I'm sorry for the difficulties you're experiencing in getting the few channels. I suggest that you unplug the TV to perform a power resetting and then perform auto programming to resolve the issue. Please let me know if the issue persists.
Dec 29, 2011 | RCA E13344 13" TV
Having a problems with my husbands Christmas Gifts it's RCA Sound Bar
Can you elaborate? What is the problem you are having? Thanks.
Dec 13, 2011 | Sony Televison & Video
NO HAVE THE CODE TO UNLOCK IT. RCA MOD. 14N26
Hello
Your TV has been locked I thinks. There is a way to unlock RCA tv, and you must V-Chip code and other things later.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 07, 2010 | RCA E13344 13" TV
Sound went out
The problem is related to sound output section, or speaker. If the sound went out while working; speaker has out. Sometimes Ic related to sound output may be damaged. Some socket problems also may arise. If the picture is Ok the sound related problems are due the above said reasons.
Oct 14, 2010 | RCA 20F512T 20" TV
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
RCA HDTV PROBLEMS
sound no picture is usally an indication of high voltage problems...the splitter maybe...the tubes maybe
Jun 14, 2008 | RCA HD52W59 HDTV Projection Television
Pitcure no sound
Try unplugging the set for a munite and check the internal/external switch on the back if this model has one. If sound is not restored you have audio circuit problems
Oct 14, 2007 | RCA P60921 60" Rear Projection Television
RCA E13344 13" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
