Question about Sharp R-530ES Microwave Oven
Lighted display no longer works
The display screen which showed a red countdown now only shows a few red dots which I can no longer decipher. How can I repair this? Thanks, Angelina
  • Sharp Master
  • 9,047 Answers
We regularly repair display / control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
But we would need to know the brand and model number to be sure we can help you.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 11, 2010
Shows "demo" and will not work
Pull the plug for a few seconds . Plug back in . With door closed try reseting clock . ( not recomended unless your a pro isid3 the main control typically behind pcb there is a chematick that will let you do a test on touch panel , pcb, and reseting the display etc.
Apr 30, 2016 | Panasonic Microwave Ovens
Microwave has power but will not program or start. Screen shows mem on display
how old is ur microwave ?
most probably its dead, if warranty available take it to the authorized repair center.
Oct 26, 2014 | Oster AM1180SS 1.1-Cubic Foot 1000-Watt...
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
I have a sharp 1900 w/r 24 at microwave, display shows a single green dot, when switched on at the wall I just hear a normal sound as if the unit is operating but nothing works
In this case as the display does not show a clock then it seems the program controller is not working correctly. So check power - step down supply, if the pads are responding- if not faulty pads. Also the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Now unless the display works and the processor starts to switch on the MAGNETRON , the table and light will also switch on as it must heat.
So it is necessary to check the main controller unit as it seems to be the suspect..
Aug 23, 2011 | Sharp Microwave Ovens
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Sounds like it's running but no heat
Those symptoms are what I would expect when the controller or keypad gets wet. Tipping it is not an issue, unless that allowed the water to run into the controls more than just the wet soapy washcloth did. You may get lucky - it may dry out by itself in a few days. If not, and if careful targeting drying doesn't fix it, it will need a new keypad or controller.
May 23, 2007 | KitchenAid KCMS145J Microwave Oven
Sharp R-530ES Microwave Oven Logo
87 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
