Question about Black & Decker Black Decker 16" Hedge Trimmer
What is the proper way to change out the brushes on a black and decker electric hedge trimmer? I took the brush holders completely out of the machine and that is evidently not the way to do it as I can't figure out how to get them back in now.
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: placement of switch mechanism
Go to www.toolpartsdirect.com and in the search box select brand and enter your model number and you should be able to find a break-down of your machine which will give you an idea as to how it goes together.I tried the GT249/H1 and GT249 as the model number and it didn't come up so you will have to look for a tag with the model and serial number on it for the correct number.
Posted on Mar 02, 2009
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
bbreton
  • 437 Answers
SOURCE: I have a Black and Decker 17
I hate to say the unit may be burned up. It may be time to go out and buy a new one.
Posted on Sep 30, 2009
  • 18 Answers
SOURCE: Black & Decker Hedge Hog 24-Inch Hedge
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Posted on Apr 29, 2010
I tried to use my trimmer for the first time this year and it won't start. It beeps and a small puff of smoke came out of the engine
Sounds like it got damp andthe motor brushes a stuck in thir holders take them out and give them a gentle rub with wet and dry paper on all surfaces after drying them gently by putting them on a radiator or similar warm place like an airing cupboard . Also put a roll of wet/dry paper into the brush holder holes so it presses onto the commutator while turning the motor This cleans the commutator If it does not work after replacing the brushes seek help from an appliance expert. Obviously if you can't get to the brushes to start with you need the expert from the start
Apr 11, 2016 | Black and Decker USA Black & Decker 12"...
How do I replace the carbon brushes on hedge trimmer GT 249
your trimming a lot of hedges if you need to replace the brushes. I'd suspect other problems before that.
Oct 14, 2014 | Black & Decker Drills
My Black & Decker trimmer starts and stops whenever I move the trimmer in any direction -- any advise as to how to solve this problem?
I'm not familiar with your machine, BUT... that description of symptom sounds suspiciously like a bad/poor electrical connection.
The problem could be in many places:
  • plug
  • cord
  • switch
  • brushes
  • internal electrical wiring
The "solution" to this problem is for someone who knows what s/he is doing, to troubleshoot the defective machine, determine the defect, and properly repair or replace the defective part.
Jun 10, 2014 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
How do I change brushes on GT524
There really isn't a manual that shows how to dismantle and re-assemble but i have included a link below for the user manual, it has a diagram showing the brushes and it gives a good idea of how to dismantle it.
Link:
Mar 04, 2012 | Black & Decker Garden
16" B&D Hedge Trimmer, No.
motor smoking is an electrical fault internally
brushes , armature of field windings problem
take it in for a proper diagnosis
Nov 13, 2017 | Black & Decker 16Inch Hedge Trimmer
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Same problem. New last fall, quit after 30 min.
The brushes for the trimmer is no longer available, so unless you can find someone who has old stock of the part, your going to have to replace this one.
Jun 15, 2009 | Remington Factory Reconditioned 17-Inch...
Black & Decker Black Decker 16" Hedge Trimmer Logo
133 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
