Mitsubishi VS-55707 Rear Projection - Power button turned on, green light on television shows power but automatically shuts back off within a couple of seconds.
  • jackpd Apr 15, 2009
    Did anyone find a solution. My VS 55707 TV was intermitently shutting off every 15 to 20 minutes, but all of the sudden I flip it on, but only the green light comes on. No picture and no sound. I would hate to throw it out when it could be an easy fix, but repair people in the area want to charge 100 just to look at it.
My brother had the same issue. I have the same set as well with this very issue. My brother had his fixed: repairman soldered the circuit board???? My brother could not tell me where on the circuit board or what circuit board???? IF there is anyone that knows about this....it would be helpful. I DO NOT WANT TO have someone else do what I can fix myself....besides by the time I pay a repairman I am 1/3 of the way or better to a new set anyway!!! Thanks a bunch - Pam
Posted on Jan 18, 2009
Mitsubishi vs50705 turn power on green button comes on then it shuts off quickly
TRY the self check here, this model may have it.
When green light comes on and goes off, on front of set press and hold both the menu and input buttons for at least five seconds and release both buttons.
Watch the power light, if it has the self check feature it will blink a two digit error code.
The most common is two blinks, two blinks, a pause and then repeat several times.
Let me know if find a error code.
SD TECH
Jan 16, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Power Problems
Try leaving it unplugged overnight. It is possible it needs to discharge. If that doesn't work, I'd say you either have a bad switch, or a bad power supply. Hopefully the switch, because that's much easier to fix. Can you bridge the switch connectors with a wire? If it doesn't come on and stay on when you do that, it's a power supply issue (and not nearly as simple to fix).
Sep 03, 2007 | Mitsubishi VS-55707 TV
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Feb 11, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Vs-55707
Press Input and menu together on the TV control panel and hold them for 5 seconds see if it blinks a two digit code.
Oct 31, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
