Question about GE Microwave Ovens
Would like to remove control panel on micro wave to get to the fuse on a ge space maker
  • GE Master
  • 9,047 Answers
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Posted on Jul 11, 2010
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
How to find fuses on my GE Spacemaker XL microwave model# JVM1340 WW
First thing is make sure you unplug the power cord. Turn the microwave around and remove the screws that hold the cover on. Remove the cover and look for where the power cord goes through the back of the unit. Follow the black wire coming from the power cord and that will take you to where the fuse is located. It might be on a small circuit board or mounted in a fuse holder or it might have an inline holder. Make sure that you replace the fuse with the same amperage fuse as you take out. You will find the amp rating stamped into one of the collars on the fuse. Good luck!
Feb 27, 2015 | GE Microwave Ovens
Ge space maker Ge model jvm1650sh01.  Serial hg
It may be a defective upper or lower door switch (or either switch's mount may be bad) or a stuck relay on the control circuit board.
Our file on door switches is here.
After you or a friend look that over, if you still have a problem, we repair these control boards for $39.95 with a one-year guarantee.
Instead of having yours repaired, you can buy a new control circuit board from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Microwave Ovens
Micro wave GE space maker 1800 is heating food well but with noise and turntable not moving,,what could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Change fuse on model#jvm1631bb002
Take the outer case off that reaches from one side over the top and to the other side. The fuse is located behind the control touch panel. Back where you will see wires, a capaister, transformer, ect. What your looking for is a fuse that looks just like an old round glass car fuse. It's not one though. It's a fuse made just for micro waves. Where the glass would be it's either black, white or tan. Noramlly it's a 20amp. Good luck.
Nov 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave is not lighting up. I have no power and the circuit is fine. it's a GE space maker 2.0 and it's only 2 years old.
THERE SHOULD BE SOME SCREWS ON THE BOTTOM SIDES OF THE MICRO REMOVE THESE SCREWS AND REMOVE THE TOP HOUSING YOU WILL SEE A FUSE SOME WHERE IN THERE CECK THIS FIRST
Aug 15, 2009 | Microwave Ovens
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
MICRO WAVE RUNS BUT IT DOES NOT HEAT
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 01, 2007 | Microwave Ovens
Microwave Ovens Logo
66 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
