Question about NEC MultiSync LCD1830 18.1" LCD Monitor
Our NEC Multisync Plasma screen monitor was functioning fine. Next day the screen was black with a few colored pixels showing. The picture returned shortly, then went to black again. Now nothing. What could be causing this?
  • 1989737 Jul 08, 2010
    Thanks so much! I will try your suggestion. Did you see my followup question? Jerry
  • NEC Master
  • 6,993 Answers
the picture board of your monitor has developed fault. You need to get the picture board for your monitor fixed.
You can also try hitting the monitor from the back and there should be a display. This is what I do when my monitor does like this.
Take care.
Posted on Jul 08, 2010
    Where do you find a picture board? Approximate cost? Can it be removed and installed by myself? Or where do I go for a repair i.e. Best Buy or a computer repair place?
  • Walesarumi
    Walesarumi Jul 08, 2010
    I would advice or prefer you take it to a computer repair place so that you won't damage anything further in the process of replacing the picture board.
    Allow a professional fix it for you.
    Good luck.
U screens colors on my pc is too bright
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Oct 05, 2011 | NEC MultiSync 1920NX 19" LCD Monitor
I have a "Multisync e222w
You likely need to adjust your Windows OS resolution to match the native one of the Multisync monitor (1680x1050 pixels).
Apr 28, 2011 | NEC E222W LCD Monitor
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Purple Screen on NEC MultiSync FE771SB
It is the problem with Monitor. Check the soldering on the crt bord, if there is any dry soldering re solder the same.
May 02, 2009 | Computers & Internet
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
May 17, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
NEC MultiSync LCD1830 18.1" LCD Monitor Logo
43 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
