Question about Sharp AFS60NX Thru-Wall/Window Air Conditioner
Smoke is coming out of the a/c
I also now hear the sound of water in the a/c. The smoke does not have a burning smell. It has no smell at all. It looks like the smoke you see on dry ice or when you first open a freezer door. It does not seemed to effected the a/c but need to know what is causing the problem and how to fix it. A smoking a/c does not look good.
  •  Christopher a Martin
    Hey Bud Try running it in a faster fan speed.The water sound could be normal is it leaking?
Ice probably formed on the outside of the unit and the a/c is working to defrost itself. Check out this page: http://andysair.blogspot.com/2010/01/looks-like-smoke-is-coming-out-of-my.html
Posted on Jul 08, 2010
Smoke and burn smell from driver side front tire, slite ringing under hood
do not drive it , havee it checked out by a mechanic
May 27, 2015 | Cars & Trucks
White smoke from air vents while ac was on,greasy film on window while defrost is on/heater coil?
Yes. The heater core is leaking bad. The white smoke is the coolant and steam. Be sure to add water to the radiator before you burn up the engine.
Oct 19, 2014 | Cars & Trucks
Smoke coming out air vents
Is it smoke or water vapor? If it's smoke, you probably have an electrical problem somewhere. If it's water vapor and you live in a very humid climate, it should dissipate soon after turning on the A/C. Is there a noticeable smell (burning plastic?) along with the smell? If so, have your car checked out by a qualified technician - it could be a fire hazard.
Oct 04, 2013 | Toyota Camry Cars & Trucks
White smoke coming from back of engine it is not water or oil problem
It sounds very much like you have a head gasket blown, or a cracked cylinder. You say it isn't water, yet you have to keep topping up the radiator. So basically, it IS water.
Nov 15, 2012 | 1999 Oldsmobile Silhouette
Black smoke from exhaust 2004 accord
Black smoke is burning oil.White smoke is due to water getting in to a cylinder from a bad gasket, cracked block or a cracked head. cracked heads.
Jan 18, 2012 | Honda Accord Cars & Trucks
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
I HAVE WHITE SMOKE COMING FROM TAIL PIPE WHEN IDILING.NOT RUNNING HOT JUST SMOKE
If the smoke has a sweet smell, it is burning antifreeze, if not, it probably just water in your fuel, add some water remover to the tank.
Feb 23, 2011 | 1992 Cadillac Brougham
White smoke and smell of eggs
White smoke in the exhaust, more so on a cold start. That's steam. Water is getting into the combustion chamber. Most likely coolant.
Put your hand in the white smoke to capture the odor. (don't burn yourself)
What does your hand smell like? Coolant (anti-freeze & water) smells sweet.
Likeliest cause = head gasket. Possible = cracked head - depending on how hot it got. Less likely = cracked intake manifold.
Maybe a blown head gasket
Apr 01, 2009 | 2006 Ford Focus
White Smoke coming out of bonnet & exhaust,stinks of burning oil 1989 dodge dynasty is blowing out white smoke now, and it does smell like burning oil, i owned a 1988 dodge dynasty and it did the same...
Sounds typical of head gasket failure.
With this you get oil into cylinders / water into cylinders, burning oil, loosing water - but no leaks. "boiling" of radiator and overflows.
Check your coolant and oil levels - they will be low.
Get a few quotes for a head gasket replacement - and timing belt change, as it has to come off when you do this anyway & no sense putting an old one on - they often snap if retensioned.
If this solves your problem, please take a moment to rate as Fixya! thanks.
Jun 22, 2008 | 1989 Dodge Dynasty
Sharp AFS60NX Thru-Wall/Window Air Conditioner Logo
127 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
