Question about Bushnell Medalist Rangefinder
Parts of numbers in display are fading or missing
Replaced battery and problem got better for a while. Now even a new battery doesn't make a difference.
Display on stove will not light
If the numbers are faded, dimmed or not even showing, the display control will have to be replaced. Thats the only repair for that issue.
Apr 28, 2012 | Kitchen Ranges
Numbers not complete on display
Apr 25, 2012 | LG Dryers
Numbers not completed on display?
The radio display is fading on Nissan Micra P reg and after a battery reconection I ccannot reset it as I cannot see numbers. Please advise
hi, i have nissan micra 1999 , the radio is orignal nissan ,the display is missing digits, please give me the solution , thanx
Feb 03, 2012 | Car Audio & Video
Display fades after insertion of new battery
Hello.
Make sure the batteries' voltage are exactly the same as the batteries you replaced. If you are still having the same issue even if the batteries' voltage are the same, update me with the brand and model of your machine.
Jul 21, 2011 | Sport & Outdoor - Others
I have a nokia 6220 classic smartphone, the problem i have is that when i switch it on the screen soon fades off again i did have a new screen fitted recently but i doubt this is causung the phone to...
hi,
i have a question. when the display fades off, does the unit still functions? i mean do you still able to make a call or receive text messages or the keypad lights still illuminates even the display fades off?
If the answer is yes, then the new lcd that you have just replaced recently is defective. have it replaced again but now to a different source. maybe the lcd that you replaced is not a good quality.
if the answers is no. have your unit reprogram, it has a corrupted software.
Hope I helped you in your problem...
Don't forget to rate me OK! thanks...
regards,
John
Jan 05, 2011 | Nokia 6220 classic Smartphone
04' Ram 1500, bad mis-fire. cust repl s/plugs. no help. Codes for coils #7 & 8 w/mis-fire. replaced coils & wire set. Better, but still P0300. Compression good
You still have random misfires (PO300)
You most likely replaced those coils that set a code, and those were not the one bad offender,spiking the computer module.
Take a new coil and put in a cylinder,no change, replace old coil and move new one to next cylinder. You can do that once or twice a day, if you have nothing else to do. You need a 90 degree day, to really get that solved,unless you have an ignition oscilloscope.
Never had a bad spark plug in 45 years.
Sep 18, 2010 | 2004 Dodge Ram 1500
Even after changing the battery, the display fades on a Timex.
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Feb 09, 2010 | Timex Sports Ironman Triathlon 100-Lap...
28112 series dect 6.0 cordless
I have seen this problem on other equipment with LCD screens. The connection between the LDC screen and the circuit board is an elastomeric connector. To see if this might be the problem, squeeze the phone along each edge of the LCD screen (front to back) and see if you can get the display to come back or get any better. If so, the contacting area on the circuit board needs cleaning.
Sep 14, 2009 | GE 28112EE2 Cordless Phone
Bushnell Medalist Rangefinder Logo
79 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
