Question about Annovi Reverberi RMV2.5G27D Pressure Washer Pump
Rkv 3.5G35 Pump is overheating so badly the plastic sight glass is melting. There was plenty of water and pump was running good until "back end" started overheating. Oil level was fine but it is now really black
2 Suggested Answers
  • 174 Answers
SOURCE: I just bought a replacement pump today. Model
The oil will be in the stainless steel or silver colored part of the pump. If there is no access to this part then the oil is put in there by the manufacturer. I believe the small red plastic plug you speak of covers the overheat blow off valve. Just leave it. When you run the washer for a long time you may see some water spill out of there. The only way to change the oil is to separate the two pump sections. Not advisable without some knowledge and the correct tools
Posted on Aug 12, 2009
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
I have a hayward s166t filter, guage reads 0 and sight glass water does not swirl when backwashed
Does it show pressure when in "Filter" mode?
If not, then your pump is either not primed, Impeller is plugged, or there is not enough water in the pool, you are sucking air.
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
How much oil does the Anrovi. RkV 4g36 take
rkv pump half of sight glass on back cover any excess can cause over flow if back cover has no sight glass then you will have to use the dipstick do as follow fill pump crankcase while inserting the dipstick til it stops without screwing it in then remove the dipstick and place the end to the pump casing if you see oil your okay cause by the time you fully insert the stick its gonna show where it should be and again half the sight glass:):)best oil to use is 30w non-detergent oil
Jun 18, 2013 | Honda Pressure Washer PSI 3000
Air bubbles in sight glass but pressure is good
leak on intake line or bad seals in pump
May 08, 2012 | Hayward Pool & Spa
Air compressor will not start.
When you are texturing walls you need a texture machine, they work very differently from an air compressor. An air compressor, especially one as small as the Central Pneumatic 40400 cannot supply the constant flow of air required by texture guns. If your compressor was running long enough to get hot enough to smell it then stopped working some of the possibilities are:
- Popped a circuit breaker, either the house breaker for the outlet you were using or the breaker on the compressor motor. This usually occurs because the compressor is being run on a too small guage or too long extension cord or run constantly for an extended period.
- Motor got overheated and seized up or shorted out. This could be as simple as a bearing seizing or as bad as the coils in the arnature shorted out.
- Pump may have seized up. Even if the sight glass shows the crankcase is full, the condition of the oil and its ability to lubricate are greatly affected if it is overheated.
Mar 13, 2012 | Chicago Pneumatic Air Tools & Compressors
RKV4G36 will not pump water. The "expert" that was using it says it needs to be rebuilt. About 3-4yrs. old with maybe 100 hours on it. Was told he started it w/o water turned on. Rebuild? New...
Bad news if he ran it without water he may have damaged the seals inside. If you screw in your water hose and water immediatly leaks from pump head then those seals need to be replaced they cost about $75. If its an RKV pump they are very resiliant and expensive they are usually worth rebuilding.
May 06, 2011 | Annovi Reverberi RMV2.5G27D Pressure...
1993 Topaz, 4 cylinder, Automatic. Will not shift into third gear. Transmission was fine until the water pump went out and took it to a shop. After the water pump was replaced, white smoke came out...
it is possible that the vacuum line for the transmission actuator was damaged during the head job
check for wiring harness connections not properly put back together
Mar 22, 2017 | 1993 Mercury Topaz
The Pump overheated
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
May 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
How do you check oil level on a u20 ir compressor do you check sight glass while machine is running or while in off mode?
Hi
No mate, you check it when the pump is not running.
Don't over fill it or it will pump oil into the tank.
That's bad news if you want to paint.
The middle of the sight glass is the correct level.
Don't let the oil get too low either.
The pump lubricates by a dipper on the bottom of the conrods. Too low an oil level starves the top end of oil and causes premature wear.
Regards Andrew Porrelli
Dec 07, 2009 | Ingersoll Rand - Rand Type - 30...
LA Marzocco group 2 machine trips 30 amp breaker
This is going to take a while because I have so many qusetions.
1- Check the external pump to make sure it is connected correctly. If neccessary also check water lines just loosen the slightly to make sure you have water flow.
2- Do you have water in the boiler? check sight glass. If no, remove vent valve and fill machine from top, until you see water in the sight glass.
3- The main switch is a 2 position switch, meaning you have off-fill-on. When turning the machine on only go one turn to the right until the autofill stops running. (this turns on the autofill which in turn sends power to the pump).
4- Check the wires at the element to see if they are damaged.
5- Check the autofill solenoid, it may not be operating properly.
May 05, 2009 | La Marzocco Linea Series Group 3 Espresso...
Annovi Reverberi RMV2.5G27D Pressure Washer Pump Logo
146 people viewed this question
Top Annovi Reverberi Garden Experts
Bill Boyd
jeff chenault
jeff chenault
Tom Chichester
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
