Question about Epson R1900 Printer
Flash alternately Flash alternative and the printer cant print
    Sergeant:
  • 275 Answers
Have you check your ink cartridge? check whether it works or not by installing to same printer using your cartridge. i think there must be broken circuit inside
Posted on Jul 08, 2010
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
The feed indicator light and ink light flash alternately (back and forth). the R800 won't print, allow cartridge tray to move, or feed paper.
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
http://www.divshare.com/download/1140953-256
Aug 31, 2010 | Epson Stylus Photo R800 InkJet Printer
Red lights flash alternately with no printing response
Hi Try to do a Powerflee
steps:
unplug all the cables including the power cable.
press and hold the power button ( On/Off) for 30 seconds
plug back all the cables and then try printing
May 07, 2010 | Epson Stylus Photo R200 InkJet Printer
I cant printing
lubricate the rod by WD-40
Apr 24, 2010 | HP DeskJet 656c InkJet Printer
Warning lights blink upon startup, printer freezes
If the lights flash alternately then it is probably your waste ink pads that need cleaning
If the lights flash continuously check your printer for any outstanding documents in the print queue and cancel them then try again
Mar 30, 2010 | Epson Stylus Color 740 InkJet Printer
When i power on my printer, flash E and 5 alternately flashing.. i cant print, scan, xerox.. pls help me. tnx much
I guess your printer is canon but you did not specify it,go to printer maintenance and view printer status for you to know what is the problem, the error maybe a cartridge problem that can't be recognized or the waste absorbent is full. Now if you see the problem and it is related to cartridge,try cleaning the cartridge contact point if it does not clear the error you can go back and I can give another solution.. Good luck.
Sep 23, 2009 | Office Equipment & Supplies
The red light then all the other lights flash alternately- nothing will print
• Reset the printer by briefly turning the printer off and back on again.
• If the error persists, contact a service representative.
Sep 14, 2009 | Samsung ML 1430 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
Re 870Cxi Lights do not stop blinking cant use the printer
You can check if the print spooling service is enabled. go to services.msc and locate print spooler, right click and select properties, select automatic as the start up type and start the service. see if it works.
Jan 27, 2009 | HP DeskJet 870cxi InkJet Printer
Canon ip3500
I have Printer Canon Pixma IP3500 has been error 6502.
What is solution? Please help me.
Jun 09, 2008 | Canon I990 InkJet Photo Printer
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
