Question about Whirlpool Duet GHW9150P Front Load Washer
Display is showing f1 - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 29, 2010
Stove showing a F1 code???
How to Fix an F1 Error On Kenmore or GE Range
Let us know what manufacturer and model displays this F1 error.
Feb 16, 2018 | Kitchen Ranges
No display on screen and external display
What is your laptop brand and model? No display on either? Does the computer seem like it is up and running, but just no display? Did you reboot when you put the external monitor on the laptop? Maybe you need to hit the FN function key and the corresponding F1 thru F12 key that toggles the display. The correct key will have CRT/LCD on it or it might show the icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 key to show the display.
If all fails, it sounds like your video card in the laptop is bad.
Apr 02, 2012 | Computers & Internet
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Display panel shows F1 Fault... how do I fix this
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 01, 2010 | Maytag MGR5750 Gas Kitchen Range
The water filter display on my whirlpool fridge showed F1% but the replacement whirlpool fridge filter that I ordered off the internet doesn't fit, so I put the old one back in and reset the display from...
hi neil.i think you do mate from what i can rember doing that when i was servicing these type of frigerators.give it a trye and see what happens.what model is it.?stef
Jun 09, 2009 | Refrigerators
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Display shows f1
Hello jrill42
Welcome,
Display shows , F1
this means your Circuit board is defective / Replace control board
You need a tech to do this work .
Please remember to leave a solved rating before you sign out!
Thank You Huum
Feb 06, 2009 | Frigidaire FEF352 Electric Kitchen Range
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Display
This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
Sgt 48
Jun 04, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
