Question about Troy-Bilt® Briggs and Stratton Chipper
Location for adding oil? - Troy-Bilt® Briggs and Stratton Chipper
  • 496 Answers
Most small engines have a cap where you check your oil level. This is also the access for putting in oil.
Here is a link to the Troy-Bilt site for chiper shredders. I don't know what model you have but you can select your model and obtain a users manual.
http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54996_54995_54995_-1#
I hope this helps you. Good luck!
Posted on Jul 08, 2010
Where to locate oil port , if any?
Look on the motors. If there is a rubber cap (sometimes metal) on each end of the motor then a few drops of oil should be put in once a year.
Oct 23, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
Where is the oil filter located
your filter will either be a canister or paper type of filter the cannister type is usually at the front of the bike engine at the bottom. If it's the paper type these are usually located under the engine .http://www.youtube.com/watch?v=_IgctXkWE-w here I've added a youtube video link on how to change your oil and filter it won't be your bike but the fundamentals are the same. Never run the engine while you are draining the oil or when the engine is drained of oil as irepairable damage will occur. hope this helps.
Sep 09, 2014 | 2008 Keeway Cruiser 250
Adding to my question about the correct location of the oil pressure switch. The car is a 2002 Hundai Accent GL. I need a PICTURE OR DIAGRAM of the location on the engine to make sure I'm working
location of oil pressure sensor on 02 hyundai accent gl with a 1.6 liter engine is driver side front of engine. lower near the bottom of the radiator.mind you that is for a 1.6 l
Apr 18, 2013 | Hyundai Accent Cars & Trucks
2000 Mitsubishi eclipse the oil light came on and my car shut down. I added 1 quart of oil and it was full but the car still won't start.
The oil light does not indicate the car is low on oil (based on your discription) it indicates the oil pressure is low, the no start is most likely due to this low pressure and the fuel pump has been cut off to prevent damage to the engine from low oil pressure. Please have a shop locate the cause of the low oil pressure warning and repair it as needed. It could be a false light or a real one, which means if you drove it very far you may have damaged the engines bearings.
Sep 24, 2012 | Cars & Trucks
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
Feb 01, 2011 | 1996 Cadillac DeVille
How do I add oil? Where is the oil fill located?
LOOK UNDER THE HOOD LOOK ON FRONT VALVE COVER THATS WHERE OIL FILL CAP LOCATED.YOU HAVE A OIL LEVEL DIP STICK BELOW THE FRONT VALVE COVER.LOOK ON THE OIL LEVEL DIP STICK WHEN ADDING OIL DONT OVER FILL THE FULL MARK LINE ON OIL DIP STICK THAT WHERE YOUR OIL LEVEL SHOULD BE DONT GO PASS THE FULL MARK.
Aug 12, 2010 | 2005 Chrysler Town & Country
How do you add oil
Generally all vehicles the oil is added through the oil cap. Which is located in the valve cover. Sometimes the oil cap will be yellow, and most of the time will be marked oil. Than pour however much oil is needed in that hole. If not sure how much is needed than add some, and than check making sure it is not too much.
Jul 11, 2010 | 1997 Dodge Intrepid
Crown vic oil change
Some of them have an oil plug at the front of the pan, as well as the regular one. You have to drain them both. The front one only holds a quart or less.
May 21, 2009 | 1990 Ford LTD Crown Victoria
I cannot find the oil filler cap on my old toro. can you help me?
Hello:
You can Locate a Breakdown that will show you the Location of the Oil Fill Cap at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Is this a 2 Cycle or 4 Cycle Engine?
If a 2 Cycle Engine, then the Oil is Mixed into the Gas and Poured into the Tank. If a 4 Cycle, then there is a Crankcase and Oil is Added to the Crankcase through the Oil Fill Cap.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Garden
Troy-Bilt® Briggs and Stratton Chipper  Logo
168 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
