Question about Hilti Cordless Hammer Drill Sfh 151 A 2.0Ah
How do i replace the jacob chuck on a hilti hammer drill?
    Scholar:
  • Hilti Expert
  • 123 Answers
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Posted on Aug 08, 2010
    New Friend:
It works, but watch your wrists. A lot of torque to get it started.
Posted on Feb 15, 2013
2 Suggested Answers
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
It has broken chuck slot, need to be replaced
You can purchase replacement chucks from Hilti. 800-879-8000. Just put the end of the chuck in the palm of your hand. with your fingers pull the sleeve towards the palm of your hand. Then just pull the chuck off.
Aug 07, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I nide a chuck for a hilti model te 805 chiping hamer
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Jan 20, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I Have a Craftsman Pro 1/2 in Hammer Drill . The Keyless Chuck is $50 plus ship and Hand. puts it over $70. Is there some type of off brand or can any replacement chuck work
Any replacement chuck will work as long as it is the right thread size and made for a hammer drill. I would try and find a JACOBS chuck for this. You should be able to pick it up locally.
Nov 12, 2009 | Craftsman Drills
Hilti Cordless Hammer Drill Sfh 151 A 2.0Ah Logo
636 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
