Question about GE PDS22LBN Bottom Freezer French Door Refrigerator
Wate light onfront of rangemaster sxs fridgefreezer turned red
Symbol for water cooler on front of rangemaster sxs fridgefreezer turned from blue to red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Posted on Apr 11, 2011
  • alexbruce Apr 11, 2011
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
A water symbol with a temperature symbol in it what does this mean?
That's the coolant temp gauge of the engine, when it's blue it means the engine is cold, if it turns red the engine is overheating, if it stays off after the blue goes out the temperature is normal.
Mar 27, 2012 | Toyota Yaris Cars & Trucks
What is the blue symbol on the panel it look like water on the bottom
The blue symbol on the panel it look like water on the bottom is the "cold engine" warning lamp. If the blue water lamp lights on the dashboard panel do not raise the engine speed too much! Only under 2000 rpm, until the blue water lamp will turn off.
Mar 12, 2011 | Volkswagen New Beetle Cars & Trucks
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Jan 17, 2010 | Refrigerators
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
Ice Cube Size adjustmentsLG SXS Refrigerator. Model GR-L-207 DVZA
If you pull the front cover off the ice maker,You will see an adjustment srew with + and - symbol ,just turn that srew.
Please rate this a fixya
Jan 30, 2009 | ASUS Eee PC 900 Notebook
Rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
Nov 01, 2008 | Rangemaster 110 (Gas) Kitchen Range
Left side fan is not working
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside teh motor and several revolutions later might get some relief until a new motor is installed.
Jun 13, 2008 | Hamilton Beach Water Cooler with Storage...
GE PDS22LBN Bottom Freezer French Door Refrigerator Logo
1,003 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
