Question about Emerson Quiet Kool 10GV13 Air Conditioner
What is the amperage draw? I need to know for sizing an extension cord.
  • 455 Answers
Hello Robin Allways use #12AWG cord size.It will handle your amp draw & not overheat.SAFETY 1st
Posted on Jul 08, 2010
What amperage is a 18 year old 24s pro tanning bed
Depends on how long the cord will be. The data plate on the bed should give you the amperage. If it only tells you the wattage used divide the watts by the volts to give amps. I wouldn't expect anything above 5 amps so the cord should be 12 gauge wire.
Jan 02, 2015 | Health & Beauty
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
Frigidaire FRA 155MT1 melted the extension cord and surge protector
You must use a heavy duty power cord with this unit as it draws alot of amerage. Most regular extension cords csnnot handle the amperage and overheat or melt.
Jul 07, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
THE POWER CORD DOES NOT REACH THE OUTLET. WHAT KIND OF EXTENSION CORD DO I NEED AND CAN I GET IT @ HOME DEPOT OR LOWES? ThANK YOU!
Look on the motor or in the instruction manual for the specifications of the electric motor. You are looking for an item called FLA or full load amps. If this number is below 15, you can use a 14 gauge extension cord, between 15 and 20, you need a 12 gauge extension cord, between 20 and 30, a 10 gauge extension cord, though that range of amperage is highly unlikely. Yes, you can get those cords at lowes or home Depot, just tell the assosiate what size you need,or the amperage on your motor, and find one in the appropriate length to meet your needs.
May 24, 2011 | Garden
Compressor will not start without tripping breaker?
Circut breakers trip due to a short circut or an overload. In this case the likely cause is an overload. If your compressor is drawing more amperage than the breaker is designed to allow, the breaker trips for safety. Possible solutions. Try using a different outlet with fewer appliances or tools on that circut. If the outlet you are using is on a circut that also has lighting, appliances etc, each item is drawing amps, the addition of the compressor to the circut is pushing the amp limit over the top. You can also try a heavier duty extension cord. If you are using an extension that is rated too low for the required amperage your breaker will trip. If you are not using an extiension cord you may need to talk to an electrician about adding another circut to service your tool and garage needs.
Another possiblity is that your service is not upgraded enough. If you have a 60amp service for the house you might want to talk to an electrician about upgrading to 100amp or more.
Jan 04, 2011 | Garden
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have a dometic duo therm rooftop a/c on my camper. On initial startup, the unit performs fine and cools until it reaches the setpoint of the thermostat. A few minutes later though after the thermostat...
Possible capacitor, but I'd check what else may be drawing power at same time in trailer. Try running everything possible on propane rather than hydro so that there is no other, or minimal current draw besides AC, and see if that makes a difference. Not uncommon in some parks, for voltage to drop when everyone using all their power as well, and the more things that draw your voltage down, before AC kicks on, will cause a higher amperage draw.
If your hooked to an extension cord as well, that will cause higher amperage draw as well, if cord not heavy enough, or too long. Try shutting everything else off, that would draw hydro, temporarily when you restart AC, just to see what happens, and let me know.
Aug 06, 2010 | Dometic Rooftop RV Air Conditioner
Air cond & electrical outlet in 1999 sprinter by keystone 33 ft
One of your breakers in your main panel should be for either one of those. Simply test receptacle for power as you try flipping each breaker off and on, until you find the right one. Quite often a high amperage draw item like electric frying pan, or hotplate plugged into the one by the kitchen area is the culprit. If they smell, or appear burnt or scorched, they should be changed, as well as the entire circuit tested for proper size wiring, as well as rated receptacle to handle big power( amperage draw). Extension cords will also cause same problem. Make sure if you have to use an extension cord, that is a heavier gauge wire, approved for that use, and is as short as possible. I'm assuming your AC is plugged in to a receptacle, and not on roof?
Apr 23, 2010 | Heating & Cooling
I have a CH WL611701AJ compressor. The motor starts and runs for approx 15-20 seconds before blowing breaker. I have replaced both capacitors, still blows breaker. Removed piston to allow motor to...
This may seem a bit simplistic but how are you hooked up to the outlet? Are you using an extension cord or is the compressor plugged in only using the supplied power cord?
If you are using an extension cord then you are going to pop the breaker every time you use it. Infact the manual states
"Never use an extension cord with this product. Use additional air hose instead of an extension cord to avoid power loss and
permanent motor damage. Use of an extension cord voids the warranty."
Air compressors don't like extension cords.
It simply draws to much for an extension cord to handle.
Depending on whether or not your warranty is out there is a simple solution. Find the biggest gauge extension cord you can
If your not using an extension cord and it's ran in the past where it's plugged in now then check the circuit because there must be new draw on the breaker
You said the breaker is 20amp. correct? The compressor should be run on a breaker dedicated to the compressor only.
Even though you should use a longer hose instead of a longer power cord you can get away with it. But forget about wire gauge size you need to think wire diameter. The extension cord I made for my compressor is approximately 3/4" thick. That is the only way I was able to use an extension cord on mine. A good place to get that size cable is a boat supply store. The cable used for shore power on boats works.
Hope this helps but if not please let me know and I'll try and help anyway I can to solve your problem.
Nov 15, 2009 | Campbell Hausfeld 28 - Gallon Air...
Have a mcCulloch eletric 300s, it runs slow and trips the breaker.
Hello. If it is tripping the breaker you will have to use a shorter extension cord, or a heavier extension cord. A brief electrical note - most residential circuits are 15 amps. There fore, go to the hardware store and get a 15 amp or even a 20 amp extension cord. This will solve your problem as long as you don't have lots of other appliances drawing on the circuit you are using. A blow dryer for instance, uses a lot of amperage, as does a microwave. Try to use a circuit that is dedicated to your chain saw for the length of time you are using it.
Jun 27, 2009 | Garden
Emerson Quiet Kool 10GV13 Air Conditioner Logo
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
