Question about Mitsubishi WS-65712 65" Rear Projection Television
What is X-Ray protect and how do i fix it - Mitsubishi WS-65712 65" Rear Projection Television
My movie is muted while using my DVD player
How to Solve Cinavia Protection Issue During Blu-ray ...
www.ideerapp.com/solve-cinavia-protection-issue-during-blu-ray-playba...
If you meet Cinavia protection when playing a Blu-ray disc, you can read below to ...uses of some movies and other filmed entertainment in Blu-ray Disc players. ... Pause the video, wait 30 seconds for the audio to be un-muted, then skip over ...
How to Get Rid of Cinavia on Blu-ray Player
www.ideerapp.com/get-rid-of-cinavia.html
The content being played is protected by Cinavia™ and is not authorized for playbackon this device. ... When you play a movie with Cinavia, meidia players or devices will be detected to ... Pause the video, wait 30 seconds for the audio to be un-muted, then skip over ... It is a free player for DVD and general video formats.
Ultimate Cinavia Guide: the protection that refuses to be ...
Dec 21, 2015 | Televison & Video
Tip
Blu-ray/DVD/Flash to HTC EVO 4G Conversion,Rip Blu-ray to HTC MP4 Great news to...
Great news to HTC EVO 4G users comes when Sprint announced the update of smartphone operating system to Android 2.2. Sprint is the first carrier to offer Android 2.2 to HTC EVO 4G with Flash support. However, there is no Blu-ray support to Sprint Supersonic HTC EVO.
Aunsoft Blu-ray Ripper is the right Blu-ray to HTC EVO 4G converter for you to enjoy Blu-ray movies on smartphone.
Rip Blu-ray to HTC EVO 4G:
You can load Blu-ray disc and DVD disc to the converter, and load BD/DVD movies from computer hard drive with disk structure.
Downscale 1080p Blu-ray to HTC:
Convert high definition Blu-ray movies from 1080p to 800x480 to fit the screen of HTC EVO 4G.
Remove copy protections:
The HTC EVO 4G converter removes the copy protections like BD+. ACCS in Blu-ray disc, CSS, region code in DVD disc, so that there is no pixilation on the output videos, and ensure smooth playback on HTC EVO 4G.
Why choose Aunsoft Blu-ray Ripper as Blu-ray to HTC EVO 4G converter?
- Convert Blu-ray 1080p to Sprint HTC EVO 4G at 800x480.
- Remove copy protections to enable smooth playback on HTC EVO 4G.
- Rip DVD movies to MP4 for HTC EVO 4G.
- Support disc conversion and DVD-file structure conversion.
Free Download Blu-ray to HTC EVO 4G converter for your Windows computer with OS like Windows XP, Windows Vista, Windows 7. It is no longer difficult to play Blu-ray movies on HTC EVO 4G. If you are using Mac computer like iMac/MacBook Pro, you may try the Mac Blu-ray to HTC EVO 4G converter.
on Aug 09, 2010 | Cell Phones
Samsung ht-f9750w blur-ray 7.1 home theater came up an error Protection then shut down automatically.
The unit has DC Offset, meaning a damaged amplifier. This issue will not allow to unit to turn until the damaged is repaired.
If you are interested in having your Samsung repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 08, 2015 | Samsung Audio Players & Recorders
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
What's your problem?my toshiba dvd player has protection on and can't get it off
The protection circuit is sensing a load problem, a malfunctioning laser assembly or a failure in the audio/video processing circuitry, far cheaper to replace the DVD player.
Mar 10, 2012 | Toshiba Televison & Video
Power comes on for two seconds then goes off. Trouble code is 21. Is this worth fixing?
The X-Ray Protect circuit monitors:
* Excessive High Voltage
* Excess CRT Beam Current
* Excess HV Circuit Current
The X-Ray line is normally High. If any of the monitored sources exceeds its' specific reference, the X-Ray line is pulled Low, shutting Off the TV. If X-Ray protect shuts the TV Off, pressing the Power button will turn the TV back On ( it will shut Off again if the problem still exist).
Possible Problems: Power Supply Fault, Sweep Circuit Problem, Doubler Board Fault or a leaking CRT. You may have bad capacitors in the power supply or the sweep power supply.
Check for CRT leaking, few drops of clear light oil. If this is leaking the fix is costly and not worth fixing.
Inspect for puffy capacitors on the power supply and sweep circuit boards, if you can solder replacing capacitors is cheap, middle pricing for replacing power supply or circuit boards.
Feb 28, 2011 | Mitsubishi Televison & Video
How to Fix X-Ray Protection Circuit
Some x-ray protection circuits would get voltage reference from the horizontal output. When a malfunction cause it to produce higher voltage, the circuit will shut it down. Look at the schematic carefully, and try to analize how the x-ray protection works. You can email me the section of the schematic that has the x-ray protection circuit, and I can help you better on solving the problem. I have worked on TV for several years, but I don't remember every model. My email is ronaldo_ross@yahoo.com
Apr 05, 2009 | JVC AV-65WP74 Rear Projection Television
Need some info tv turns on then goes off
Good Day,
Try these:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jul 01, 2008 | Mitsubishi WS-55807 TV
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Apr 13, 2008 | Televison & Video
Mitsubishi WS-65712 65" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
