Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair 34700 recovery problem
My ser number is 22447. Date Code 0298. In recovery mode the machine will only run for several seconds, and then it shuts off for high pressure. I have verified that the recovery solenoid is opening. The compressor is running. The machine high and low guages show that the vehicle has 75psi. We connected an auxillary guage to the port just before the filter drier and it shows shows 35 psi when the machine is trying to recover.
  • hager_lucas Jul 14, 2010
    Today, I ran the machine in recycle for approx. 30 minutes. The machine ran as expected. Following the recycle, I ran it in recover without hooking it to a vehicle. It Pulled the lines down into a vacuum after a minute and shut off showing complete at the end of cycle. That was perfect. I hooked to a vehicle. It recovered perfectly. I have no idea what I did. I may have had some blockage that the recycle or vacuum pull cleared. Not sure. But, it works.
    President:
  • 180 Answers
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Posted on Jul 10, 2010
  • Hasan Khan Amran
    Hasan Khan Amran Jul 14, 2010
    Yes,you are right! There was blockage somewhere in the manifold assy.that the recycle or vacuum pull cleared! You can continue to use the machine. but remeber every time when you press recover, do not skip "Clearing in pogress" mode. because during self clearing machine test it self to work normal.
Machine won't recover, it gets stuck on "clearing in progress" Also won't vacuum, it says that "pressure exist press any key to continue" Your help would be greatly appreciated
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
Aug 18, 2015 | Robinair Cool Tech 34700Z Recovery,...
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Whirpool washer Mod:GHW9100LW2 Ser:CSP4706448 giving a fault code F/H and I need part# for pressure switch
Open the back, on the left side half way into the washing machine, you will see a thin service manual. Mine says F/H means No water detected entering machine or pressure switch trip not detected.
Part number 8181695
Apr 17, 2013 | Washing Machines
Robinair 34700 hi-p
Disconnected Air Purge lines. It was under high pressure (careful).
Feb 29, 2012 | Robinair Cool Tech 34700Z Recovery,...
HOW TO RESET AFTER MAINTENANCE
You should write which Model of Robinair machine you have! Because it has several reset process for different models. so please specify your Machine model.
Feb 24, 2011 | Robinair Cool Tech 34700Z Recovery,...
34700 unit when in the vacuum mode it sends R134 into the oil recovery bottle tank
Please check oil drain sensor(switch) or oil drain solenoid for any debris. If both are check OK, then check Vacuum,Recycle and charge solenoid for any debris or damage. Replace/rebuild as needed. Hope this will help you
Nov 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
34788 cool tech will not accept new filter codes tried two different filters and is locked out of recovery
It will not unlock till you enter origenal robinair Spin-on filter code! Try with this code FD32C46B01. This is a free gift for you. Good luck & don't forget to vote it.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
HP Mini 110 shut down during scan disc not booting up
Try hitting the F8 button on the keyboard a screen comes up with several options move to safe mode and hit enter on the keyboard if it boots up to safe mode hit the NO tab when it asks to go to SAFE MODE you then can do a system restore to a date that you know the computer worked....this is a restore not a recovery and you will not loose any of your documents or pics etc....
Jul 07, 2010 | HP Mini Notebook
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
941 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
