Question about Whirlpool LER4634J Electric Dryer
Drum rotation direction
The drum in this dryer is rotating in a counterclock wise direction. How do I change the direction to clockwise?
catriver
  • 878 Answers
SOURCE: kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
Posted on Aug 31, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Posted on Feb 26, 2008
  • 198 Answers
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Posted on Jan 07, 2009
SolutionGuy
  • 331 Answers
SOURCE: Model LEQ9858PWO Whirlpool Electric Dryer-- Wife heard a clunk.
Your wish came true, DS! Click here and browse through the sub-components section.
Your lucky day,
SG
Posted on Apr 06, 2009
  • 351 Answers
SOURCE: makes loud, squeaking noise when dryer drum is
could be a roller or idler
Posted on Jun 28, 2009
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Jan 09, 2011 | Frigidaire Electric Dryer
Too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Jul 25, 2010 | Air Tools & Compressors
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Which way do I turn the main bolt on crankshaft to get main pulley off. I went counter-clock wise and it broke the braker bar.
you turned it the right way but will have to use an air impact to get it loose or a hammer to hit the ratchet or breaker bar with, you need a half inch drive breaker bar to get it loose and it will have to be in gear and the emergency brake on to get it loose.
Jul 15, 2009 | 1995 Isuzu Rodeo
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Older Matag Dryer - continued chat
Hi again Tom,
You can post the images here by clicking on the middle icon (before You Tube) top left. The only limitation is that the picture file be 150kb or smaller.
Sorry about the email, prudence dictates that all communications related to your post be out for all to see.
Cheers.
May 27, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
296 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
