Question about Poulan Garden
My weedeater xt260 runs but stops when I give it gas
  • dan_moneo Jul 08, 2010
    Thanks, but I have rebuilt my carb, so I will try the foam.
  • 10,865 Answers
Hi. Most likely your carb or your engine is gunked up a bit. Get a bottle of a fuel additive called seafoam, from most any auto parts store. Follow the directions on the bottle and add it to your fuel and then run it. Within a couple of minutes your problem should be solved. If it is not, the next step is to have the carburator rebuilt. J.
Posted on Jul 08, 2010
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I have a weedeater featherlight which is discontinued, but anyway where is the setscrews on the carb i need to tune it!
they are covered,if you need to tune it then you need to clean and rebuild the carb and replace gas lines,buy it all on ebay for less than 20 bucks,ethanol kills plastic,buy the whole carb,you cant adjust yours
Jul 26, 2015 | Garden
Will not start it ran and juat stopped I can put gas in the choke and plug it will run for a few seconds and stop
Ethanol gas wrecks Carburetors and Gas lines. Just for giggles see if the Stone filter in the gas tank broke off the dried out gas line.
Jun 27, 2015 | Weedeater 25cc Gas Blower ()
My weedeater worked one time and then it stop working not sure why it stoped i need to know how to fix it
well did you run straight gas or mixed fuel...
straight gas... throw it away and find another one
mixed... we need more info like how long it's sat ???
Aug 09, 2014 | Weedeater / Craftsman Igniton Module...
Weedeater featherlite xt260
Small engine shop google that and good luck
May 30, 2014 | Garden
Can't find owners manual for the following weed eater model numbers xt-200, xt-260 and poulan model # p35oo
XT200: http://www.weedeater.com/ddoc/WEEO/WEEO2004_USen/WEEO2004_USen__530163333.pdf
XT260: http://www.weedeater.com/ddoc/WEEO/WEEO2010_USen/WEEO2010_USen__545186831.pdf
P3500: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007_545154718.pdf
Sep 06, 2011 | Garden
17.5 Tecumseh stops running with 1/2 tank
Check your gas gauge to see if it is working correctly. Is there any dirt in the tank?
Oct 03, 2009 | Garden
WeedEater Featherlite String Trimmer fuel leak.
give it a week to see if the fuel hose swell and stop leak sometimes i have the same problem.
and ill wait for a week and it quits leaking.try that
Jul 30, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Garden Logo
141 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
