Question about Omega Blazer Self - Igniting Butane Micro - Torch - the Original
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it. Thanks for the help-
  • Anonymous Mar 13, 2014
    Replace flint on bernzomatic micro torch
  • 10,865 Answers
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Posted on Jul 08, 2010
How to change the flint on micro torch roburn mt-770
There is no flint.
It uses a piezoelectric igniter. Not really replaceable.
Point it at yourself at arms length and see if you can see a spark when you press the button to start it.
Here is a video which shows how to adjust the air-gas mixture when the torch is new.
Jul 21, 2016 | Miscellaneous
I have a small pencil torch its not flaming right.not torching just a flame
Too much gas! Turn it down and check that nothing is blocking the airways.
Mar 23, 2015 | Blazer Pencil Micro Torch PT 4000
How do I refill the blazer es-1000
On the Bottom there is a Insert and you used the Pressurized Can to fill it
Nov 07, 2014 | Blazer Es1000 Angled Head Butane Micro...
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Butane torch
Could be due to the fine gauze in the nozzle becoming clogged due to maybe not using good quality gas refills?.
May 08, 2013 | Blazer GB2001 Self-Igniting Butane...
My Ronson butane torch won't light
probably has bad fuel in it. get new stuff. cheep fuel sucks.
Mar 06, 2013 | Cars & Trucks
Blazer pocket micro torch will not spark. Gas comes out, but no spark to ignite it.
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
May 03, 2011 | Omega Blazer Self - Igniting Butane Micro...
Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Omega Blazer  Self - Igniting Butane Micro - Torch - the Original Logo
2,151 people viewed this question
Top Omega Welding Tools Experts
Bill Boyd
Are you an Omega Welding Tool Expert? Answer questions, earn points and help others
