Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Sony DCR-HC26 Tape Deck won't close
I have searched for help within the FixYa site and saw there are a few people with this same problem.
I also saw this as a suggestion:
"That means tape mechanism has problem and might be cam gear is broken. Need to replace complete tape mechanism under following part number..
A1080997A MD (N100) SUB ASSY A
Available in Nextronics for $63
Below is an image of required tape mechanism.
Thanks."
MY QUESTION IS:
Is the tape deck assembly for the HC26 the same one as the HC28? Because the link to this Nextronics replacement assembly goes to the HC28, even though the original poster posted about their HC26 model (which is the same as my broken model).
Thanks,
YahYah
  • 7 Answers
SOURCE: Sony Handycam DCR-HC28
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Posted on Aug 22, 2008
SOURCE: Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Posted on Nov 08, 2008
  • 89 Answers
SOURCE: Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Posted on Jun 18, 2009
welcomejee
  • 10594 Answers
SOURCE: tape deck won't close after tape inserted sony dcr-trv103 r
Do you see any error code flashing at top right in camcorder LCD?
Let me know that error code please.
Posted on Sep 03, 2009
avastph
  • 92 Answers
Follow what they say
Hi, I have a Sony dcr hc26 camcorder, the deck where you would put tapes in is stuck open and will not close. Is this something you are able to repair?
Fixya does not offer either a repair or replacement service, merely advice. My advice in this situation is to take the camcorder to a repair facility.
Jan 06, 2017 | Sony Video Cameras
Tape bay does not close
Something is either clogged in the tape bay mechanism or there is something actually in the space it occupies.
Jan 20, 2013 | Sony DCR-HC26 MiniDV Digital Handycam...
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Sony handycam DRC-HC26. After placing the DV tape the tape refuse to load into the tape compartment and as such the tape door cannot be closed. Please advise.
The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly.
This will solve your problem.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
No idea how to get video from DCR-HC26 to macbook
why you don't connect it to DVD rcorder and record it then finalize and watch even on the compter. good luck
Sep 26, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Need a manual for a Sony handycam DCR-HC26
here is the manual for ur camera just read and Be a MAster of ur camera
http://www.docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Pls rate me FIXYA fo rhelp
Apr 22, 2009 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
353 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
