Question about Samsung CLP 300 Laser Printer
Samsung Ml-2525W printer-Red light flashing after printing 3 docs
Pulled out tray, checked paper and behind tray. Opened printer, took out ink cartridge. Could not see any paper jam or any problem. Turned printer off and back on a couple of times, get nothing but flashing red light. Is there anything else I can do. I do not have a manual or any documentation. Printer is only 6 weeks old.
flopez
  • 161 Answers
SOURCE: Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Posted on Sep 22, 2007
SOURCE: document feeder jammed - cleared jam - now jams everytime
through yahoo I found an hp manual - turns out there was a bar on the lid that faces the glass that I hooked under the backing - worked like a charm - stinks that the manual that came with the printer did not include any problem solving or details - the online version had 260+ pages - good luck
Posted on Apr 01, 2008
SOURCE: ink cartridge carrier jam
Once it jams on the left turn off the machine. usually my lights are all red at that point, one is blinking the other two are solid red. open the cover. shine a flashlight in there, you will see a clear or light grey plastic ribbon that runs from the left to the right. it is the top most thing. Very carefully, clean it with a paper towel and a little water. or a kleenex. it should be almost clear.
after done, move the cartridge head to the right without turning on the printer. once again, clean the clear plastic ribbon where the cartridge head was located. finally turn on the printer, when it stops initializing, click the paper feed button, if you were successful, you won't see it jam into the left side.
if not, try repeating again. I think the optical head could also have some junk on it, and will deposit it back on the clear grey plastic strip.
the clear strip passes through the cartridge head. I'm told it is called an encoder strip and the optical head reads the strip to know it's position.
when that strip is dirty or covered with some ink spots, the print/cartridge head, can't read it and slams into the side the the printer.
this happened to my c80 at least 3 times now in seven years.
Posted on Feb 14, 2009
  • 13 Answers
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Posted on Mar 08, 2009
indus3
  • 212 Answers
SOURCE: Samsung ML 1710 won't print second page
i'm thinking it's a config-related problem. i've seen a comparable problem already. could you check the settings in the printer software? there is setting that says "print first page from different tray" if its box is checked, the printer wants to print the rest of the print job from another tray, and will block when there is no other tray available.
if you find this setting is not marked, then i propose to delete the printer driver and all settings and then downloading the most recent driver from the manufacturer's website and installing that one.
Posted on May 27, 2009
How to clean ML-2525W Mono Laser Printer ?
did you try a different toner cart if you did and it still does this it is your laser unit. try the cartridge first if it still does it then take it to your local samsung dealer.
Aug 28, 2014 | Samsung ML-2525W Mono Laser Printer -...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
Samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
Oct 08, 2009 | Samsung ML-1640 Monochrome Laser Printer
May 25, 2009 | Samsung ML 1710 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Series: the error red light is blinking
reset the printer by opeing the front over and closing it again.
check all area for paper jam. i.e.: paper tray, ink cartridge, out put tray.
Feb 28, 2009 | Samsung ML-2510 Laser Printer
Samsung CLP 300 Laser Printer Logo
2,354 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
