Question about HP Officejet 5610 All-In-One InkJet Printer
Using a HP5610 O-Jet, saying Cartridge Error, has been working good with this cart. then poops out today. saying to refer to t-shoting to device doc, dont have one, what to do please
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
you must change color cartridge (hp 22) with a new one or refill an older one if you have
if i help you pls vote
Posted on Oct 30, 2010
Cartridge Error: Refer to documentation to troubleshoot. message. have replaced both cartridges and turned on/off both computer and printer, and unplugged usb connection too.
You must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP5610 is not a new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | HP Officejet 5610 All-In-One InkJet...
Saying cartridge error when cartridge is inserted correctly
CLEAN JACK OF CART. & THE CARTRIDGE ITSELF & INSTALL YOUR CART. AGAIN
REMEMBER IF YOU USE REFILLED CARTRIDGE IT WILL SHOW ERROR ,SO ITS BETTER TON USE GENUINE HP CART.(ON INSTALLING GENUINE CART. IT WILL ASK FOR ALIGNMENT SO CLICK ALIGN WHEN PROMPTED.)
Feb 12, 2011 | HP Officejet 4355 All-In-One InkJet...
When I want to take a print the printer displays cartridge error : Refer to device documentation to troubleshoot. What can I do
USE GENUINE HP CART. I THINK YOU ARE USING REFILLED CART.
SECOND CLEAN THE CARTRIDGE JACK IN PRINTER ALONG WITH CARTRIDGES USING SOFT COTTON CLOTH.
Feb 08, 2011 | HP Officejet 4355 All-In-One InkJet...
HP 5610-Keep Getting: "Cartridge Error"
  1. My HP5610 was acting up with the error in cartridge thiny.
    I held down the # and the 3 and reset the unit and it is back
    in business.
  2. Is there any other error messages? Like carriage jam or something? If there are no other error then try to do a partial reset on your printer, to do that follow these steps:
    Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE.
  3. But before throwing away the (supposed broken) HP5610 I made the last attempt: I gave it the power with the new power supply and...surprise, the printer worked perfectly!!
Feb 22, 2010 | HP Officejet 5610 All-In-One InkJet...
HP 4215 all in one printer. Cartridge error
Hello Barry
It is odd that the machine is not telling you which one.Mine usually does.Okay
the best way and cheapest way for you to figure out which one it is, the unit takes a HP 56 and HP 57,which are very common carts,used in the HPs today,If you can get your hands on two
different carts and exchange them around you will be able to find out which one it is.They do not necc. have to be full ones.Once you find out which one it is get a new one.I would be willing
to take a guess it is your black one
Feb 06, 2010 | HP Officejet 4215 All-in-One Color Photo...
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
I am receiving the ?Print cartridge problem-[Tri-Color] refer to device doc. to troubleshoot.? Error message on my Hp j4580. There is no help in doc and nothing I?ve tried (cleaning etc.)works. Should I...
I had the same problem. I called hp and spent an hour running through the troubleshooting things that I'd already done. They ended up sending me a new ink cartridge, and surprisingly, it worked. For some reason, the printer refused to recognize a nearly full ink cartridge. Go figure. It seems to be working for now, but it's a huge waste of ink and money. If you have the patience for it, call hp and see if they will replace your cartridges.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
My printer says "Cartridge Error" refer to documentation...What can I do I have taken out the cartridges and still no printer. I don't have the device doc
You need new cartridges, they have a date stamped on them when they expire, if you have refilled cartridges, they sometimes don't work at all. If you have cleaned the electrical contacts on the cartridge and in the carriage with alcohol. and still get this error, you have to try a different cartridge.
Aug 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Printer reads out "Print Cartridge problem (Tri Color) Refer to device documentation to trouble shoot" I purchased this HP Officejet J4550 All-in-one unit new and haven't made any color pictures with it....
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
Mar 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
