Question about Kenmore 19110 Computerized Sewing Machine
I have a new kenmore 19110 sewing machine and cant get it to sew a stitch. I have changed the bobbin thread twice and rethreaded the top thread two or three times, changed the needle size. What else can I do?
    Problem Solver:
  • 4 Answers
Check the treading of the bobbin. it isn;t like my old singer I followed the directions in the manual.
Posted on Jul 17, 2010
Why first four to five stitches will not interlock
try changing needle
try rethreading machine
also could need a adjustment or have a timing problem
Feb 27, 2016 | Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
Kenmore 385 81808 sewing machine will run, but stiches do not appear on fabric.
try changing the needle--make sure it the right needle for the fabic
being sewed
also try rethreading the sewing machine top & bobbin
make sure to use every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the sewing machines timing needs to be
checked at a sewing machine shop
Oct 04, 2012 | Sewing Machines
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Top thread is ok but bobbin thread misses stitches at will, zigzag stitches don't sew but a straight line. changed needle, sanded burrs off pressure plate, cleared bobbin chase of lint. what have I...
check tension usually 3 or 4 is good
clean under needle plate where feed dogs are for lint
is the flat side of the needle toward the back of the machine
rethread machine
is needle the right one for the fabric & thread
it might also need to be serviced
Nov 24, 2010 | Kenmore Sewing Machines
Have been given an old frister rossmann 402 machine with no maual so i cant work out why it sews some stitches and becomes hooked up underneath by loopy threads
change the needle
rethread the top thread make sure the thread doesn't come off the thread take up lever
check the bobbin area for lint or loose threads
also rethread the bobbin in the bobbin case & reinsert it
also check the top thread tension try 3 or 4
Nov 04, 2010 | Sewing Machines
I can't get the thread tension right. The bobbin thread comes up through the top and makes bumps. The underneath is loopy and uneven. It's brand new, right out of the box!
Try this..
1) set your tension @ 4
2) rethread your machine up to the needle
3) lower presser foot
4)pull thread . If it pulls hard, machine is threaded right. If it pulls easily, it's not.
Rule of thumb:: Loops on the top, problem is on the bottom.
Loops on the bottom, problem is on the top.
Hope this helps.
Apr 29, 2009 | Kenmore 19110 Computerized Sewing Machine
LED shows 5P or SP
take the bobbin winder post (the silver metal post on the top to the right next to the spool of thread and push it to the left toward the spool of thread. The SP means it is in Spool mode.
Oct 12, 2008 | Kenmore 19110 Computerized Sewing Machine
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
Sep 05, 2017 | Sewing Machines
Kenmore 19110 Computerized Sewing Machine Logo
120 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
