Question about Fuji FP-768 17" Flat Panel LCD Monitor
Green light on - no picture
PC crashed. Monitor was disconnected for 2 wks while being repaired. Upon reconnect I get no picture. Greenlight comes on. Occasionally blinks. Any suggestions?
  • 11,361 Answers
I would take the PC nad the monitor to the repair shop and have them find out if the PC is out back together correctly by trying with another monitor, if it works with another monitor, then you will have to take apart the monitor to inspect the inside for bad components.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 09, 2010
The problem of my lg monitor sometime not working properly continues blinking only,sometime good condition
If you monitor light coming then ok, but i think RAM not proper display so you check it keyword numlock button light or not. If numlock Light coming then your PC ok. And then you change monitor power cable and change it. or some time disconnect monitor power or also disconnect cup attachment. then reconnect proper i hope solved you problem.
If not Solved then contact Good PC Technician.
Thanks.
Tech Support Mart Computer Support
Feb 17, 2014 | Computers & Internet
On off switch seems not to work. both greenlight
yes you can fix it on your on.., just remove the battery on your motherboard and put it back
Jan 15, 2010 | HP Pavilion 8650C PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
The green light turned red and now it green light
Dear,
Just disconnect the monitor data cable from PC and see, any cable discunnection message comes in Monotor. If that comes in monitor, there is no issue with it
Oct 13, 2009 | HP Compaq dx2000 Microtower PC Desktop
Hi, my TW-191 suddenly quit working yesterday. . . it is only 2 years old? When the PC is first turned on the amber light turns green and the screen is displayed then after a few seconds goes blank....
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 26, 2009 | Hannstar I-Inc TW-191D Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Monitor will not come on
Most of the tiime if the monitor has a blinking green or amber light there is a problem with the signal going out to the computer. there are 2 ways how we can determine if the it is an issue with the monitor or the video card of the computer.
Since, we have a new monitor cord that could eliminate the possibility that your monitor cord causes the problem.
1. Try disconnecting your monitor from the computer and check for the green blinking light
2. Try connecting a different monitor to determine the issue.
Keep me posted.
Jeff
Oct 12, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Fuji FP-768 17" Flat Panel LCD Monitor Logo
57 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
